Thread: Swooshing sound audible in car on acceleration.
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Swooshing sound audible in car on acceleration.
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    This started yesterday.
    The hiss (bellow,whoosh) sound happens on acceleration when turbo kicks in. There is slight black puff of smoke .
    The noise seems to come from the passenger side.
    I am hoping a hose has a leak.
    No error codes on scanning.
    Help !
    2.7tdi avant quattro
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  2. Re: Swooshing sound audible in car on acceleration.
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by poosnip View Post
    This started yesterday.... i don’t know What it is but it doesn’t sound good.
    There is also a little black smoke.
    Help !
    Please give more details I.e of the sound being made, when it happens any idea of where it's coming from, does black smoke and noise happen at the same time and only then
  3. Re: Swooshing sound audible in car on acceleration.
    Jun 2010
    10 Post(s)
    The sound happens on acceleration when turbo kicks in. Smoke is slight black puff.
    The noise seems on the passenger side.
    Previous:
  4. Re: Swooshing sound audible in car on acceleration.
    Nov 2016
    england
    33 Post(s)
    Any performance change?what engine do you have? Size, fuel, code
  5. Re: Swooshing sound audible in car on acceleration.
    Jun 2010
    10 Post(s)
    2.7 tdi bpp.
    No real performance change . Actually its a bit faster.
    Previous:
  6. Re: Swooshing sound audible in car on acceleration.
    Nov 2016
    england
    33 Post(s)
    2.7 tdi bpp.
    Being a sound coming from passenger side I'm inclined to think maybe egr or turbo related but I'm not looking at it so can't guarantee that's right and it'd difficult if it hasn't thrown up a code, if it's a recent thing it may throw up a code after so many runs so keep an eye out for one, is it only when being driven or stationary while revved too if so you need to have someone rev it so you can find the source (a bit of tubing can help with this if you are having trouble,use something like what carries your screenwash)
  7. Re: Swooshing sound audible in car on acceleration.
    Nov 2016
    england
    33 Post(s)
    2.7 tdi bpp.
    Also does the exhaust kick out any distinct smell that's unusual
  8. Re: Swooshing sound audible in car on acceleration.
    Jun 2010
    10 Post(s)
    Quote Originally Posted by Nard666 View Post
    A bit more burnt combustion smell than the usual slightly cleaner (post catalytic coverter smell).
    I have seen an oily resedue at the intake... you know the visible pipe with an electronic intake valve near the front of the engine
    Previous:
  9. Swooshing sound audible in car on acceleration.
    Jun 2010
    10 Post(s)
    There is no swoosh or hiss when revved stationery only when moving . It is definitely turbo related and sounds like a pressured system that is compromised . I just wish i knew how to get at the offending piece
    Previous:
  10. Re: Swooshing sound audible in car on acceleration.
    Nov 2016
    england
    33 Post(s)
    Black smoke is often to do with the air /fuel ratio being off so maybe not enough air, you mean the piece of ducting that leads out to the front of the car (the air intake that goes through to the air filter and from then onto the turbo? I have a 3.0 tdi sorry I have to make sure so without checking the 2.7 tdi engine lay out.....) oh man that shouldn't have oil there I'd check your air filter see what that's like you do often get a little oil in the damper (the bit on the non exhaust side next to the turbo) but it shouldn't be much and shouldnt go that far back maybe you have an oil pipe to the turbo gone or a oil seal or bearings gone in the turbo that may affect the blades in the turbo spinning round and not provide enough air, what do you want to get to on the car, the turbo? I may be able to help with that by guiding you but I'm puzzled there's no codes for turbo you may need to look into getting whatever codes it did give if possible it would be a good insight it may have thrown up a code me or someone else knows more about as audi drivers and DIY repairers or technicians where as your garage may not have seen them before
  1. Question Not sure if I have a problem or not - whistling sound under acceleration
    By chrishamer in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-02-2016, 04:24 PM
  2. Question Slight whistling sound under acceleration
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2013, 10:46 PM
  3. Question Knocking sound (inconsistant) on acceleration from engine (1995 Audi Coupe 2.0E - ABK engine)
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-11-2010, 07:51 AM
  4. audible locking
    By reddevil7 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-10-2010, 10:02 PM
  5. No Audible Alarm Sound - A3
    By Laynet in forum Chat - Anything with wheels
    Last Post: 26-09-2009, 05:09 PM
