Thread: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
  1. 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    Dec 2014
    10 Post(s)
    Question:
    Appreciate vacuum tubes, N75 and MAF options are still valid but has the innotec or powerboost(?) cleaner option fallen out of favour these days?
    Waffle:
    Think I've been got by the same thing as this recent thread (but thought I'd start my own instead of hijacking it):
    Possible Turbo problem?
    Car lost power above 2k rpm this morning but other than that seemed fine. On the drive home power had returned and once it had warmed up this time gave it a few revs and went up the same hill I'd crawled up in the morning fine. Got back and VCDS said the fault code in the title.
    Just been slaving through the threads that came up in a search for "17965". Seems that most of the time people have been suffering gunked up VNT vanes.
    This innotec cleaner http://www.innotecworld.com/products...hp?productid=6 seemed to be considered an option back in the day (some of the threads my search pulled up are ~10 years old now). In the thread above I noticed Crasher jumped straight to turbo rebuild as the most likely way to resolve an overboost.
    Cheers,
    Ian
  2. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    Apr 2018
    N.Ireland
    9 Post(s)
    Try revive turbo cleaner I've had success on over ten tdi's with clogged veins, cleans a lot more than the turbo as well so a good service item.
  3. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    Jan 2009
    Birmingham
    36 Post(s)
    Only way to completely fix the problem is a turbo rebuild or fit a refurbished turbo unit.
  4. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    134 Post(s)
    2007 Post(s)
    Chemical cleaners are snake oil, they do not work. If you could see how much bead blasting force is required to blast off the carbon you would dismiss fluid treatments in an instant. I tried them and they do not work, in fact those that contain water, damage the turbine shafts and piston rings by causing rust. There is no substitute for doing the job properly.
  5. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    Dec 2014
    10 Post(s)
    Ok thanks for all the replies. Seems like I need to find somewhere that does reconditioned turbos.
    Ian
    Sent from my XT1039 using Tapatalk
  6. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    May 2012
    Everywhere
    308 Post(s)
    Mr Muscle twice & wiggle actuator arm .
  7. Re: 17965 - Charge Pressure Control P1557 - 35-00 - Positive Deviation
    134 Post(s)
    2007 Post(s)
    I have seen Mr Muscle cause turbine shaft piston ring failure due to rust as it is water based but chemical treatments just don't work long term if at all. The last time I did one using Innotec was about 15 years ago on a 98 A3 TDI, it took the arm from sticking to stuck... Funnily enough the same chap is in today but with a different car, about three down the line, turbo not long rebuilt but blowing oil out of charge air pipes, over boosting, coolant full of oil, rattling DMF....
  1. Charge Pressure Control: Negative Deviation
    By iainst26 in forum Octavia
    Last Post: 06-07-2010, 06:52 PM
  2. 17965-charge pressure devation p1557-35-00
    By yuley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-05-2010, 05:40 PM
  3. Question 17965 - Charge Pressure Control: Positive Deviation
    By mobitune in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2009, 06:17 PM
  4. Please Help 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    By sanchezuk in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2008, 09:36 PM
  5. 17958 - Charge Pressure: Control Deviation
    By andy1max in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 08:39 PM
