Thread: 2010 golf 2.0 tdi
  1. 2010 golf 2.0 tdi
    Mar 2018
    NOTTINGHAMSHIRE
    Hi guys, new to VW's and the forum. Just purchased a 2010 VW Golf 2.0 tdi, car has got engine management light on with a code of P064100 As this is my first VW any help in pointing me in the right direction to find and sort the problem would be gratefully accepted.
    Thanks in advance
  2. Re: 2010 golf 2.0 tdi
    Jun 2016
    Glasgow
    What’s the code description?
  3. Re: 2010 golf 2.0 tdi
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by supertrooper View Post
    Thanks in advance
    P064100 doesn't look correct what was used to get this code? All EOBD II Codes are 5 characters starting with a letter B, C, P, U. If I take the 00 of it shows.
    VAG Error Code: 17025/4123
    EOBD II Error Code: P0641
    Fault Location:
    Sensor Reference Voltage 'A' - Open Circuit
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Fuse(s).
    Wiring/Connector(s).
    Engine Control Module (ECM)
    harness is open or shorted.
    Engine Control Module (ECM) circuit poor
    electrical connection,
    Shorted sensor on 5 volt circuit.
    Engine Control
    Module (ECM).
    When is the code detected?:
    The Engine Control
    Module (ECM) has detected the sensor 5 volt reference circuit voltage is higher
    or lower than expected.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: 2010 golf 2.0 tdi
    132 Post(s)
    1979 Post(s)
    As Keith says, you need to get a proper code read done, I have had similar codes to this recently and as it is vague, the reasons can vary and sometimes I have to use the dealer system ODIS under the Guided Fault Finding function to get to the bottom of the problem.
  1. golf mk6/eos 2010 wireing
    By satman78945 in forum Golf MK6 - 2009 - 2013
    Last Post: 01-04-2015, 02:04 PM
  2. 2010 mk6 golf 140 gt tdi EGR COOLER
    By nathan6301 in forum Golf MK6 - 2009 - 2013
    Last Post: 28-04-2014, 08:15 PM
  3. VW Golf 2010 1.6 TDi SE
    By danny64698 in forum Golf MK6 - 2009 - 2013
    Last Post: 07-03-2014, 03:06 AM
  4. 2010 Golf Mk 6 Estate 1.6 TDI.....Vag Com
    By cabledeck in forum Golf MK6 - 2009 - 2013
    Last Post: 09-09-2013, 02:06 PM
  5. VW Golf 2010 MK6 TSI 122
    By adamnsu in forum In Car Entertainment
    Last Post: 19-06-2013, 05:56 PM
