Thread: MK4 golf 1.9tdi egr valve.
Results 1 to 10 of 18
  1. MK4 golf 1.9tdi egr valve.
    Mar 2018
    Uk
    Hi All,
    First Post.
    Does anyone know if the egr valve on the above car run on vacuum only?
    i have removed the egr and attached a vacuum pump to the vacuum port and there are two little wholes either side of the valve which I blocked and pumped the pump to build a vacuum and the tappet inside doesn’t move? Should it move under vacuum or does it neen exhaust gasses to help push it up?
    Warm regards,
    Scott.
  2. Re: MK4 golf 1.9tdi egr valve.
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It should move under vacuum, but you shouldn't have blocked the little holes. unblock the holes and see if you can pull any vacuum on the diaphragm? maybe the diaphragm is split inside the actuator housing
  3. Re: MK4 golf 1.9tdi egr valve.
    May 2012
    Everywhere
    308 Post(s)
    What plate and year is the Golf ?
  4. Re: MK4 golf 1.9tdi egr valve.
    Mar 2018
    Uk
    Sorrry it’s an 02 plate, I blocked the little holes with only my fingers, with out creating a seal on the little hole on the egr valve it doesn’t create any vacuum. Even with blocking the holes the tappet doesn’t move only when I reallease the vacuum and the tappet jumps a few mill.
    The vnt is ceased half way so that’s got to come off and cleaned. The symptoms I get are limp mode and a general lack of power the car is mapped stage 1 or maybe a custom map.
  5. Re: MK4 golf 1.9tdi egr valve.
    May 2012
    Everywhere
    308 Post(s)
    Sorted.
    No more egr , no eml .
    Next job is to Mr Muscle the hot side of the turbo
  6. Re: MK4 golf 1.9tdi egr valve.
    Nov 2010
    104 Post(s)
    I think your diaphragm is split then
    Quote Originally Posted by ScottVKG View Post
  7. Re: MK4 golf 1.9tdi egr valve.
    Mar 2018
    Uk
    Quote Originally Posted by Gazwould View Post
    Sorted.
    Did you put a bolt bolt in the vacuum pipe?
    What about the egr valve opening the tappet inside to recerculate the gasses?
  8. Re: MK4 golf 1.9tdi egr valve.
    Mar 2018
    Uk
    Iv tried the mr Muscle and the vnt is still seized.��
  9. Re: MK4 golf 1.9tdi egr valve.
    Mar 2018
    Uk
    Thank thank you everyone for your reply’s
  10. Re: MK4 golf 1.9tdi egr valve.
    May 2012
    Everywhere
    308 Post(s)
    Yes bolt , the egr actuator receives no vacuum so no egr plunger operation , if it's stuck partly open , blank .
  1. Vacuum solenoid valve? 1.9tdi bkc
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 26-04-2016, 12:32 PM
  2. Replies: 0
    Last Post: 03-12-2013, 11:51 PM
  3. 1.9TDI jerking/no turbo after replacing EGR valve
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-07-2011, 06:52 PM
  4. Question egr valve for 2003 1.9tdi 130 awx engine
    By spartan80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2010, 04:03 PM
  5. dump valve a3 1.9tdi
    By brickyman1984 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-06-2010, 08:18 PM
