Thread: Febi front upper control arm bush failed after 18k miles ????!!
  1. Febi front upper control arm bush failed after 18k miles ????!!
    Nov 2016
    2006 A6 C6 2.0Tdi 183k
    Less than a year ago I replaced the front upper drivers side control arms. A month ago I replaced the front shocks and lower control arms and the car felt really good to drive again. But now it's all over the place, to the extent that even my Mrs commented on it! (She one raced off in car to get the kids, and only realised after parking two miles later, the trailer with over half a ton of sand in it hanging off the back!)
    The front upper control arms are Febi and have done about 18k miles. If I put a pry bar on the rubber bushing, it is really really lose, easy to push it sideways all the way. I can hold the arm with my hand and rotate it a bit, quite easily.
    I would have expected far more from Febi parts. Even considering the shocks were worn out for a long time, so the suspension probably moved far more than it should have, does the make sense?? I'll replace just the bushing rather than the whole arm (as I can't face trying to remove the pinch bolt again) and see how it goes. Is this normal???????
  2. Re: Febi front upper control arm bush failed after 18k miles ????!!
    135 Post(s)
    2039 Post(s)
    Did you tighten the bolts with the suspension loaded or unloaded?
  3. Re: Febi front upper control arm bush failed after 18k miles ????!!
    Nov 2016
    OK, In this instance, the top control arm bolts were tightened with the suspension fully extended. All my ones since then have been tightened (despite difficult access) with the suspension compressed.
    Is that why they've failed.... my fault on installation??!!
  4. Re: Febi front upper control arm bush failed after 18k miles ????!!
    135 Post(s)
    2039 Post(s)
    Yes. You can do that with Polyurethane bushes such as Powerflex but not with bonded sleeve bushes, it rips them apart.
  5. Re: Febi front upper control arm bush failed after 18k miles ????!!
    May 2008
    40 Post(s)
    Quote Originally Posted by Feneris View Post
    We used to get the same with the trucks, all finger tight until all wheels on the floor then tighten everything up.
  6. Re: Febi front upper control arm bush failed after 18k miles ????!!
    Mar 2009
    Montenegro
    13 Post(s)
    You should buy Lemforder. I have never had problems with them.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  1. allroad front upper control arm angles
    By ben0069 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2013, 03:43 PM
  2. Question Upper Arms failed
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-04-2011, 08:53 AM
  3. upper front control arms
    By DGT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-08-2010, 07:52 PM
  4. upper control arm bush
    By kaborex in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2009, 06:04 PM
  5. Which control arms meyle, febi, vag ?
    By jemthetaxi in forum Passat - Archive Topics
    Last Post: 17-03-2007, 08:51 PM
