Out of the blue at the end of 2017 my stop start stopped working. I initially thought the stop start wasn't working as a result of low tyre pressure. However, the problem has persisted. Could anyone please advice on how to fix this issue?
Code:
Sunday,14,January,2018,11:47:48:64250
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: xxx License Plate: yyy
Mileage: 149828km-93098mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: xxx Mileage: 149828km-93098miles
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 0100
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H83 4943
   Revision: 00H83H22
   Coding: 011D0012036505083000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AF1E804FD25A396DF-802E
3 Faults Found:
5290 - Throttle Actuator Control Circuit
          P2100 00 [104] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 148256 km
                    Date: 2017.12.15
                    Time: 08:49:38
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 15 °C
                    Intake air temperature: 10 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.680 V
                    Unlearning counter according OBD: 40
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 100.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.02 %
                    Throttle valve adapter 1 bank 1: monitoring - status-Bit 0: 0
                    Throttle valve adapter 1 bank 1: monitoring - status-Bit 16: 9
                    Throttle valve adapter 1 bank 1: monitoring - status-Bit 24: 55
                    Throttle valve adapter 1 bank 1: monitoring - status-Bit 8: 2
                    Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4506.2 mV
20558 - Heater Support Pump
          P16C6 00 [032] - Running Dry
          Intermittent - Not Confirmed - Tested Since Memory Clear
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:55
                    Engine speed: 871.50 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 66 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.100 V
                    Limitation: accelerator pedal: 0.0 Nm
                    CAN status - engine control module-Bit 0: 0
                    Cruise Control System (CCS): status-Bit 0: 1
                    CAN status - transmission control module-Bit 0: 0
                    CAN status - brake control module 1-Bit 0: 0
                    CAN status - brake control module 2-Bit 0: 0
                    selected gear-Bit 0: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01302020099
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 152BDBB8F47B6CEE52-8040
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
   Component: ESC           H75 0537
   Revision: 00000000    Serial number:
   Coding: 01FA8AA120210A6F037D060301C92980510450C0608094F3F86A5028C1
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7EF9E414E10D8FB6E3-802A
3 Faults Found:
8192 - Databus
          U1121 00 [137] - Missing Message
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:55
8196 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:55
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 71
                    Reset counter: 191
                    Mileage: 149134 km
                    Date: 2017.12.30
                    Time: 11:07:06
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0206610423
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 79F3F708F823A88ED6-802C
No fault code found.
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5G0 907 426 K    HW: 5G0 907 426 K
   Component: AC Manuell    H01 0503
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 336F05209ACF92DE5C-8066
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011306001655
   Coding: 03011846C241027B0FA44080B11C0728180A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46894CF4F95D1776EB-8012
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    130217  042 0551
   Serial number:         130222072350
   Coding: 0E4DD5
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y13M02D22H07M39S40S1
   Coding: 00A8DD
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130382NFG
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000056047921
3 Faults Found:
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 133
                    Mileage: 148128 km
539925 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 149005 km
                    Date: 2017.12.26
                    Time: 18:20:02
934149 - Rain/light recognition sensor
          B1366 76 [008] - Wrong mounting position
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 175
                    Mileage: 149395 km
                    Date: 2018.01.05
                    Time: 10:03:38
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231305500207
   Coding: 0071051011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_002_VW37.rod
   VCID: 3A712804BDA563969F-806E
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R01YHGZ
   Coding: 98CCC000000000005C0000CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 4A9178C4ED45F3160F-801E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677A01031340101
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676A01031370178
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 202 13
   Component: SideSensor_Df  001 0887
   Serial number: 3576700000059B28DC02
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 202 13
   Component: SideSensor_Pf  001 0887
   Serial number: 3586700000075B113C0Q
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 502 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502AD0F8ABF2510Q
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 502 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502A90F8ABF4C27/
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 602 13
   Component: FrontSensor_D  001 6149
   Serial number: 3556502BF0F7B8E39291
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 25021308490526
   Coding: 0C00
   Shop #: WSC 40195 333 37120
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 020190E495F5EB5687-8056
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5G0 920 960 A    HW: 5G0 920 960 A
   Component: KOMBI         236 0555
   Coding: 27A401182780260001886A01040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 2757E1705E17EE7EF0-8072
3 Faults Found:
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:46:00
16776960 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:54
16776961 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:54
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000384787
   Coding: 030100040B087300EF00045C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 346D063C9FC195E645-8060
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H12 0034
   Serial number: 02120004537170090291
   Coding: 2D0000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8020799101
1 Fault Found:
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [009] - Performance
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:45:58
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
Address 2B: Steer. Col. Lock (J764)       Labels:| 5Q0-905-861.clb
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000019468004
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73EFC520DA4FD2DE9C-8026
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 25021301100469
   Coding: 003B1220D001048000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
   VCID: 3F875910A68746BEA8-806A
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000000868765
   Coding: 0D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7B2318AC8B54AEBA-8068
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 20021303110868
   Coding: 003B1020DE01048000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
   VCID: 3E792414A18D4FB6A3-806A
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000000862897
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 858     HW: 5G0 035 858
   Component: MU-S-ND-ER    039 0170
   Serial number: V5F00103130041
   Coding: 02730001FF0000002111120100A800001F0100060100010045
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 69D3A7488883180E26-803C
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9M34018JG
   Data medium:
   Subsystem 2 - Part No SW: 5G0 919 866 D    HW: -----------
   Component:  ECE 2013  --- 0021
   Serial number: --------------------
2 Faults Found:
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:46:00
                    Voltage terminal 30: 14.3 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 149058 km
                    Date: 2017.12.28
                    Time: 10:46:00
End-------------------------(Elapsed Time: 03:57)--------------------------
I would really appreciate any help on this, many thanks
