Thread: Deformed oil filter
  1. Deformed oil filter
    Feb 2014
    Anyone have any idea why my ( MADE IN THE USA ) oil filters get sucked in like this. 2008 Passat 2.0
    Thanks Greg
    IMG]https://uploads.tapatalk-cdn.com/20171218/5bbb678e74f4f340153178932681f1be.jpg[/IMG]
    Using Tapatalk
  2. Re: Deformed oil filter
    Mar 2016
    Minervois, France
    54 Post(s)
    It looks to me that it has been collapsed by pressure from the pump, due to the filter material being blocked.
    Either your oil was very contaminated or the filter is of poor quality.
    I once had an air filter (on a Mini) sucked in in the same way in wet weather when the filter medium became impervious due to the moisture, and actually stopped the engine.
    I had to remove it to get the engine running again. I suppose it is possible that your oil filter became blocked in a similar way due to being stored in a damp place.
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
  3. Re: Deformed oil filter
    Feb 2014
    Quote Originally Posted by FrenchAudi View Post
    Thanks, I know the oil wasn’t that dirty, about 3000 miles, I’m going to assume a lower quality filter. I have a 2003 Golf TDI with 260,000 miles and never had a problem. Thanks you
    Using Tapatalk
  4. Re: Deformed oil filter
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    That is down to the membrane media becoming blocked causing the filter to collapse in on itself. I suspect either low quality filter and/or wrong grade of oil used. You can see where the pleats of material have collapsed. Luckily for you, you have only done 3k so hopefully you wont of starved your engine of oil.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  5. Re: Deformed oil filter
    2014 Post(s)
    Never mind the obvious waisting, look at the twisted writing, possible twist deformation due to inadequate lubrication of the matting faces as the cap is torqued down.
  6. Re: Deformed oil filter
    Feb 2018
    Carbis Bay
    Do you know what make if filter it is.
    Regards
  7. Re: Deformed oil filter
    Feb 2014
    Quote Originally Posted by jeeringtowser View Post
    Regards
    Hello jeeringtowser, I don’t remember the brand, I think I got them at ROCKAUTO and knowing me I’m sure I went for the cheapest. Now I’m using MANN and no more problems.
    Using Tapatalk
  1. Air filter and cabin filter change on Touran 1.6Fsi.
    By driver2008 in forum Touran - Sharan - Caravelle
    Last Post: 29-12-2014, 11:09 PM
  2. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  3. Replies: 6
    Last Post: 04-01-2013, 01:08 PM
  4. Cabin Filter Seal - Is it visable with filter removed?
    By jammy86 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2010, 06:46 PM
  5. Air filter,pollen filter,diesel filter Audi a4 130 sport.
    By KIDDAJOJO in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2008, 09:07 PM
