Thread: Please help vw passat 1,6tdi cayc
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Please help vw passat 1,6tdi cayc
    The maximum is 60gr
  2. Re: Please help vw passat 1,6tdi cayc
    I did the dpf regeneration. The injector mg/stroke are now
    -2,88
    -0,39
    -0,07
    3,41
    Injectors had been on bosch service and they are ok. I entered code. Now I'm thinking, is anyone done "adapting injector minimum deviation quantity" ? Maybe I need to do that. Because I know for sure that 4tg injector quantity was before 2-3weeks 0,88 , and now is 3,41
  3. Re: Please help vw passat 1,6tdi cayc
    135 Post(s)
    2029 Post(s)
    You have two faulty injectors and a 2/3 blocked DPF and unless you deal with those you will get nowhere. Are you sure the IMA coding is correct and the value verified? Who reconditioned these injectors?
  4. Re: Please help vw passat 1,6tdi cayc
    Injectors were recondition in bosch service. They are working with lot of injektors. I did dpf regenerate and now there is only 10gr
  1. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    By nickbell1uk in forum Golf MK6 - 2009 - 2013
    Last Post: 10-10-2017, 04:55 PM
  2. Golf 1.6 tdi 105 - 2010 CAYC - normal values in MAF (g/s) ?
    By alb_duar in forum Golf MK6 - 2009 - 2013
    Last Post: 07-03-2017, 03:31 PM
  3. Audi A3 - 8P - 2010 - 1.6 TDI (CR) - CAYC - Timing Marks
    By DCEd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-04-2015, 10:12 PM
  4. passat 2010 1.6tdi estate bluemotion
    By mbev51 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-03-2014, 07:23 PM
  5. passat 1.6tdi bluemotion estate
    Last Post: 03-03-2014, 02:12 PM
