Thread: Please help vw passat 1,6tdi cayc
Results 1 to 10 of 14
  1. Please help vw passat 1,6tdi cayc
    Hello, I have problem with my passat 2013 1,6tdi cayc engine code. When I firts start car , car work ok and driving is ok. But the problem is when i turn off car and let it a little to cool, or when I drive a short distance and turn it off, then when I start it, it start perfect and idle is ok, but after 5sec idle is starting jump up and down and engine is working bad. Then I give take it to 2000rpm, and start druving , after 5meters car work again ok. Injectors were on repair and they are cleaned and are ok. Bud this problem is still there
  2. Re: Please help vw passat 1,6tdi cayc
    135 Post(s)
    2027 Post(s)
    Have you had a code read done? Has the car had the stupid emissions recal carried out?
  3. Re: Please help vw passat 1,6tdi cayc
    Yes I coded injectors by vcds. Injectors are tested in bosch service, but when i look on injector amount by vcds, they have first 2,2 second 1,6 3th 1,7 and 4th injector 1,9mg/stroke
  4. Re: Please help vw passat 1,6tdi cayc
    I filled 20l of diesel from another gas station and the car is working a little better. I will fill it up, and see then
  5. Re: Please help vw passat 1,6tdi cayc
    Feb 2018
    Might be linked to the emissions recall as crasher pointed out
    Sent from my Redmi Note 4 using Tapatalk
  6. Re: Please help vw passat 1,6tdi cayc
    I drived car 14km in 4th gear and on 3000rpm, to do catalisator burning. But no light is shown on dashbord, maybe i must to aktivate it manual by vcds? And the consumation per hour when is cold is 1,4l/h on 1000rpm at temp of 4-5celsius. And when is engine temp on 90grade, the consumption os on 0,6l/h
  7. Re: Please help vw passat 1,6tdi cayc
    135 Post(s)
    2027 Post(s)
    Have you had a code read done? Has the car had the stupid emissions recall carried out?
    As I asked, have you code read the fault memory of the ECU and has the car had the emissions recall? To initiate a forced DPF regeneration you have to enter the code using a diagnostic system.
  8. Re: Please help vw passat 1,6tdi cayc
    There is no fault memory on car. I will do dpf regeneration by Vcds
  9. Re: Please help vw passat 1,6tdi cayc
    On diagnostic is showing 44,7grams in dpf filter??
  10. Re: Please help vw passat 1,6tdi cayc
    135 Post(s)
    2027 Post(s)
    What does the info box say is the maximum? It is usually around 80 grams.
  1. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    By nickbell1uk in forum Golf MK6 - 2009 - 2013
    Last Post: 10-10-2017, 04:55 PM
  2. Golf 1.6 tdi 105 - 2010 CAYC - normal values in MAF (g/s) ?
    By alb_duar in forum Golf MK6 - 2009 - 2013
    Last Post: 07-03-2017, 03:31 PM
  3. Audi A3 - 8P - 2010 - 1.6 TDI (CR) - CAYC - Timing Marks
    By DCEd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-04-2015, 10:12 PM
  4. passat 2010 1.6tdi estate bluemotion
    By mbev51 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-03-2014, 07:23 PM
  5. passat 1.6tdi bluemotion estate
    Last Post: 03-03-2014, 02:12 PM
