Thread: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
  1. No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Mar 2007
    Ipswich, UK
    7 Post(s)
    As above, I lock the car and if I leave the roof down when I reach into the car the hazard lights start flashing rapidly but the alarm does not sound, the following fault codes are present, would a failed siren cause these or would it be the other way around, the faults are stopping the alarm from sounding? Also there appear to be lights in the drivers door alarm switch but if I try pressing the switches the lights in don't come on?
    If it's the siren at fault am I wasting my money buying a second hand one given the issue is likely to be failed internal batteries? I would really appreciate any advice.
    6 Faults Found
    01134 - Alarm Horn (H12)
    29-00 - Short to Ground
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01373 - Alarm triggered by Radio Ground Contact
    35-00 - -
  2. Re: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Aug 2011
    Aldershot
    6 Post(s)
    I could be very wrong, but I'd start by looking at the wiring loom going from the A pillar into the drivers door. Inside the loom is 4 fat wires and 4 thin wires, from my experience, 155k miles car, 2002 model, 3 fat wires and 1 thin wire was broken, I was getting all sorts off issues, with locking, alarm, windows door mirrors, eventually I gave in and replaced this wiring loom,
    It was not cheap, about £130 from memory, but solved most of my issues.
    Like you say, any second hand alarm will likely already have a flat battery which needs replacing. Unless you are desperate to make your alarm work, on an older car now, I'd be hesitant to spend too much money on a new siren.
  3. Re: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Sep 2008
    chester
    17 Post(s)
    Waste of money buying a secondhand one the batteries leak acid,very common problem with these units,clear out the fault codes and check with vcds it'll give you the last four alarm triggers(can't remember the block number)you will set off the alarm by reaching in that's normal,on a car that old I wouldn't bother unless its going off in the middle of the night.
  4. Re: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Mar 2007
    Ipswich, UK
    7 Post(s)
    It's not going off at all sound wise let alone in the middle of the night, I just don't like having things that should work but don't, not sure whether you'd call it OCD but it just bugs the hell out of me.
  5. Re: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Sep 2008
    chester
    17 Post(s)
    If you've got a bad one the acid migrates along the wires and connector requiring a new connector splicing in.
  6. Re: No sound from alarm, doors lock indicators flash but would a failed siren cause these fault codes?
    Mar 2007
    Ipswich, UK
    7 Post(s)
    Well I've discovered that the alarm switches on the drivers door do work as do all the other switches on the drivers door so I'll take a punt that it's the actual siren in the boot and order one up and replace it when I'm of next week.
  1. No alarm sound or lock/unlock chirp
    By cobology in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2011, 10:01 PM
  2. Question Sharan. Can I lock my doors without activating the alarm
    By sharansporttdi in forum Touran - Sharan - Caravelle
    Last Post: 12-05-2011, 03:46 PM
  3. Question alarm sound not working (no hazard flash when locking)
    By Niz1 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-09-2010, 07:45 AM
  4. Alarm - No Siren - Indicators Flash. - Any ideas ??
    By RickT in forum Golf MK5 - 2004 - 2009
    Last Post: 03-06-2009, 08:44 AM
  5. How To make indicators flash when doors are locked
    By sarah14 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 04:24 PM
