Thread: 06 C6 Power Tailgate Issue
Results 1 to 10 of 11
  1. 06 C6 Power Tailgate Issue
    Apr 2014
    Congleton
    Hello all. Recently my powered tailgate in my 2006 A6 Avant has been playing up and it’s slowly got worse. Initially I noticed it wasn’t latching. I have to press down on the tailgate to get it to “click” in order for it to lock. It used to close firmly, now it is very gentle and doesn’t seem to latch. Maybe 1 out of 10 times it’s ok.
    Also along with this, the tailgate won’t open on the first attempt. Sometimes it opens about a foot, and I have to press the button again, sometimes when I release the button it immediately bashes closed (only time it really latches on its own!!) some times it opens only an inch and re latches shut. Other times it works ok. You can hear a mechanical latch releasing when you press the button.
    So in summary;
    More often than not, it won’t open on the first second or third attempt. I have to just keep pressing the button until it finally opens. Sometimes I have to help it. Opens a little then bashes closed.
    and
    It won’t latch closed on its own, I have to press down on it in order to get it to latch, 98% of the time.
    I have a video if it helps.
    What’s happening here?
    Thanks folks!
    Nick
  2. 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    You need to change the mechanical motor, there is a known problem for our car. Change the motor and everything will be like new.
    If you need the part number just give me the car info, I can take a look in etka.
  3. Re: 06 C6 Power Tailgate Issue
    Apr 2014
    Congleton
    Thanks for that! Is it a DIY job do you know?
  4. Re: 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Yes it is easy to fit. I did it myself.
  5. Re: 06 C6 Power Tailgate Issue
    Apr 2014
    Congleton
    Where are the motors located?
  6. 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Do you have saloon or avant?
    Sry I read now you have avant. There is only one motor located under the protection of the door.
  7. Re: 06 C6 Power Tailgate Issue
    Apr 2014
    Congleton
    2006 Avant
  8. 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    You have multiple v clips that fits the carpet like protection on the door. Just look for some bolts that fits it on the door, remove them and pull the protection from its clips, firmly by hand.
  9. Re: 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Just take care you don’t brake the clips since they are sometimes very sensible. Pull with force but with care.
  10. Re: 06 C6 Power Tailgate Issue
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Look for exemple i did it for you now, some pics: w
  1. power tailgate issues
    By quattrogary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-08-2017, 01:30 PM
  2. Please Help Avant power tailgate and lock malfunction
    By andylef in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-05-2017, 08:50 PM
  3. Question Tailgate strut pivot nut issue!
    By GE90 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2016, 10:00 PM
  4. Retrofitting power tailgate to a Passat Estate?
    By TimS996 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-03-2014, 04:53 PM
  5. Getting sick of the problems! Resetting power tailgate?
    By 5678 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-08-2012, 11:07 PM
