Thread: P0046 turbo actuator fault
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: P0046 turbo actuator fault
    #21
    Jul 2008
    Lisburn
    15 Post(s)
    so it started to play up again - this time worse when the car got hot the turbo switched off!!! Output tests cold all looked fine from 20 to 80%, when it got hot it was stuck at 9%..
    so i wen in for another look. it appears i moved the big black gear when taking the cover off and this was fouling - so pshed it back home and all was well again -mine is different from the picture on page one - I have a bare shaft coming out of it.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  2. Re: P0046 turbo actuator fault
    #22
    Jul 2008
    Lisburn
    15 Post(s)
    Another update - sorry for popping this back up top all the time but i hope it will benefit someone having all the info. refer back to post #8 for a picture to better understand what i am going on about....
    So it started playing up again FFS - just as well its not that hard to get to.
    Same sot of thing so i thought this time I will glue the gear to the shaft - bad idea its an idle gear.
    the shaft is 4mm thick - and it goes into a hole in the housing 7mm wide - so no room for a clamp. Solution - dont laugh - i cut the end off a raw plug to stop it from moving out and fouling with the drive gear on the motor. i used a bigger one that was left floating and cut it to length so that it would also spin if need be was the idea, other options would be a tight one to act as a stop, but this would then need lube itself? or, i was thinking of dry graphite grease in the edge of the gear that was fouling the other gear - Blame Ed in an episode of botch it up and ship it out (wheeler dealers).
    Anyway i hope this is useful to someone.
    As ever i will update if i need to go in again.
    Stewart
  3. Re: P0046 turbo actuator fault
    #23
    Jun 2022
    Aberdeen
    Great post.
    Resolved limp mode issue relating to the boost pressure sensor (P0235/00565) and actuator signal (P3348/13128) codes.
    2005 (C6) A6 Avant 3.0 TDI Quattro
    symptoms were the car would start from cold and run all day with no issues until it was switched off and then started again. Would then enter limp mode with the glow plug light flashing and then the solid engine warning light would also illuminate if driving continued. Once the car was left to cool overnight the issue would disappear until such time as the car was up to temp then switched off and on again. I was Nader the impression it was either a temp or vacuum issue until I saw the above thread and gave it a try. Remove the turbo to air box pipe, breather and a few wiring multi plugs to give yourself room and as a precaution to not damage any wiring. A fairly straight forward job although both the bottom two torx screws (T20) on the actuator cover are quite fiddly and be careful to remove the cover squarely so you do not damage the two internal terminals on the cover side. Well worth the 30-40 mins taken to complete the whole task.
    once again, great post and many thanks.
  4. Re: P0046 turbo actuator fault
    #24
    Jun 2022
    Aberdeen
    Quote Originally Posted by WarrenA6 View Post
    Just to update... the fault returned and I opened it up and rather than using oil I used a temperature resistant grease... very thick and painted all the gearing. It's been good for a couple of weeks now. This actuator is a very simple system. If you're one is going wrong the only two things that can go wrong commonly are sticky veins on the turbo or a weak motor on the actuator... by greasing the gearing you are reducing the stress on the worn motor... replacing the motor is the easiest remidy if greasing don't work and the veins are ok.
    Sent from my SM-G950F using Tapatalk
    Great post.
  5. Re: P0046 turbo actuator fault
    #25
    Jul 2008
    Lisburn
    15 Post(s)
    Glad you got sorted, however mine eventually fully failed. When it does have a good garage up your sleeve that will swap out yet actuator only. I had loads wanted to remove turbo and send away, a few needed the old one working, but I did fond a garage that swapped it out no bother.
  1. Please Help Actuator arm on turbo
    By Rocco Boy in forum Golf MK6 - 2009 - 2013
    Last Post: 17-02-2018, 12:16 AM
  2. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  3. Passat 2008 turbo actuator fault
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2014, 07:09 PM
  4. Heater fault - Actuator motor fan temperature flap fault
    By jackdaw1990 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2013, 02:30 PM
  5. turbo actuator
    By meganall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2012, 01:28 PM
