Thread: ABS/ESP Light on Handbrake light flashing
  1. ABS/ESP Light on Handbrake light flashing
    Feb 2018
    London
    Hi Everyone,
    New to these forums and was looking to see if anyone has had this problem before,
    On my way home from work tonight I turned a corner and 3 beeps along with the handbrake light flashing, both esp and abs lights came on my dashboard along with brake fault drive carefully to nearest workshop. I have a A3 1.9TDIe 58 plate. Although with all these warnings the braking system felt fine. Took it into a empty car park to test and the car is still functioning normally.
    I'm planning on taking it to my local garage tomorrow but if anyone has any ideas of what it could be/ what can I expect i'd appreciate it.
  2. Re: ABS/ESP Light on Handbrake light flashing
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Could be loads of things - it needs a scan with decent VAG relevant diagnostic system, not just generic OBDII, make sure your local garage has that capability. Anything else is guesswork until that's done.
  3. Re: ABS/ESP Light on Handbrake light flashing
    131 Post(s)
    1973 Post(s)
    2009 model A3 Mk60.1 pumps have a nasty habit of failing, the give away fault code is one reporting ECU failure (I have the number at work) and the only solution is to replace the ECU or have it rebuilt by someone like BBA who did one for me this week.
  4. Re: ABS/ESP Light on Handbrake light flashing
    Feb 2018
    Fife
    Arent these often repaired by the manufacturer foc like VW do with the Mk5s? They dont go offering it but if you know about it they will do it for free!
  5. Re: ABS/ESP Light on Handbrake light flashing
    131 Post(s)
    1973 Post(s)
    That good will campaign only applied if the fault code pointed at the G201 sensor but the campaign ended a couple of years ago and as far as I know was only being offered by VW dealers. Without knowing what the fault code is, it is pure conjecture and Audi would want you to commit to a full on diagnostic at £120+ to even begin the process with no guarantees of help further along.
  1. polo flashing handbrake light
    By Jk2 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-02-2014, 10:36 PM
  2. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  3. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  4. Please Help flashing handbrake light
    By peter cutmore in forum Golf MK4 - 1999 - 2004
    Last Post: 02-01-2011, 06:43 PM
  5. handbrake light flashing and beeping
    By johnnyboy in forum Passat - Archive Topics
    Last Post: 26-10-2007, 08:13 AM
