Thread: shaking passat
  1. shaking passat
    Aug 2007
    hi
    Ihave just had cambelt break and garage had head off etc no damage but now the car shakes when driven between 1600-2000 rpm(similiar to missfire or even wheel balance) only on acceleration no shake on overrun this is very noticeable in 4th and 5th. Out of that rev range the car is smooth
    The garage have said they now think the dual mass flywheel needs replacing this was replaced 40,000 miles ago (before Iowned car)
    The car did not do this before going into garage
    The clutch does not slip or judder at all
    I have faith in garage but wonder if they are right
    any help would be appreciated
  2. Re: shaking passat
    london/ UK
    Chances are that some valves were bent and not seating properly. At tickover, the ECU is controlling the smooth running by constantly monitoring the engine rpm. If the engine speeds up, then he is injecting less diesel to the next injector to slow the rpms. If one of the pistons is loosing conpression, you will have the same issues. Did the garage done a leak-down test ?
  3. Re: shaking passat
    Pretty unlikely from what youve said, but having the cambelt break could possibly have damaged clutch, and maybe even the flywheel. The clutch is effectively the fuse between engine and gearbox....
    The drive straps could bend if the engine seizes, but that wouldnt cause judder, more it wouldnt clear/disengage.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  4. Re: shaking passat
    Aug 2007
    thanks garage confirmed that head was pressure tested and again when fitted back on engine was leak tested said it was ok
  1. Shaking under power
    By Urbane Fox in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-11-2007, 11:50 PM
  2. VW Bora 1.6..shaking problem
    By rsj84 in forum Bora - 1998 - 2005
    Last Post: 23-08-2007, 03:01 AM
  3. Mpg Very low /car shaking / Idle Too High I Think
    By minz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-07-2007, 08:31 PM
  4. shaking at high speeds
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2007, 09:57 AM
  5. Golf MKIV Shaking
    By sunilnc in forum Golf MK4 - 1999 - 2004
    Last Post: 20-05-2007, 12:15 PM
