Thread: Re 2013 Passat imobiliser active steering display on dash in yellow
  1. Re 2013 Passat imobiliser active steering display on dash in yellow
    Jan 2018
    kettering northants
    Hi all i,m looking for a bit of advice i have a 2013 Volkswagen Passat Diesel my dads car that he's had from new done 40k and been superb until the other day he put the key in the ignition and it wouldn't start no ignition lights just says imobilser active and has a yellow steering light on the dash, he had noticed a few issues starting it the other day but by taking the key out and putting it back in again it started, Have tried a new key reader, didnt make any difference, akward as i cant get a scanner to communicate due to no ignition lights, also all of the windows went down, was able to get them back up again holding down the lock button, we do have two keys and both are the same.
    Any help would be greatly appreciated Many Thanks Dan
  2. Re: Re 2013 Passat imobiliser active steering display on dash in yellow
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Sounds like a problem with the steering wheel lock. Maybe waggling the wheel while inserting the key will allow it to work but if the lock is the problem then you will most likely have to get it replaced. There are several videos for the B6 units.
  3. Re: Re 2013 Passat imobiliser active steering display on dash in yellow
    Jan 2016
    Winchester Hants
    29 Post(s)
    Maybe a reset to default...disconnect the battery for a while.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  4. Re: Re 2013 Passat imobiliser active steering display on dash in yellow
    Jan 2018
    kettering northants
    Problem solved it appears that the battery was flat although did have enough power to flash the lights upon unlocking as well as unloking the car and also enough juice to put all four windows up but obviously not enough to turn off the steering lock or deactivate the imobiliser, it appears with modern cars you just have to go back to extreme basics, we were to quick to assume the worse and overlook a flat battery, although it was recovered in and seems the recovery guy overlooked a flat battery too.
    Thought id post this just incase anyone else has blonde days as well
  1. Active Info display retrofit
    By MattB247 in forum Passat - B8 Forum - 2015 -
    Last Post: 09-08-2016, 04:00 PM
  2. Active Info Display
    By jimgironde in forum Passat - B8 Forum - 2015 -
    Last Post: 15-07-2016, 05:57 AM
  3. Please Help Passat B7 Immobilzer Active No Lights On Dash No Crank
    By pz_szczecin in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 22-10-2015, 02:26 PM
  4. Active Info Display release
    By lozzer62 in forum Passat - B8 Forum - 2015 -
    Last Post: 04-09-2015, 09:11 PM
  5. Question Yellow Steering Warning Light on Dash with no Symptoms.
    By ric4676 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-03-2012, 10:03 AM
