Thread: Manual gearbox oil change
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Manual gearbox oil change
    May 2006
    Redruth, United Kingdom
    Quote Originally Posted by didkobandita View Post
    Hello there
    Can anyone help me and give an advice regarding, the oil capacity, the oil specification and changing interval for a 6 speed manual gearbox and the same for the rear differential?
    I have a 2.0TDI 170BHP quattro 2008 with a 6 speed manual.
    The reason I start considering to change the oil is because when the car is cold the 1st gear is a bit stiff. I own the car since new so it has never been that way.
    Any help will be much appreciated .
    I would go with a straight 75W for your gearbox, particularly the sintofluid FE75W
    Pardon Our Interruption
    You need a 75w-90 GL5 oil for the diff
    The Millers CRX NT, Motul Gear 300, Red Line 75w-90NS, Amsoil Severe Gear and Gulf Competition are ideal as top end options. The Millers TRX Synthetic/EE Nanodrive, Mobil SHC, Castrol Syntrax Universal Plus and Valvoline Synpower TDL are good, but a step down from the top oils. Fuchs Gear Syn, Motul Motylgear, Millers TRX Semi and Castrol Universal are good, cheaper options.
    Off the top of my head its around 3 litres for the gearbox and 1 litre for the differential.
    Regards
    Jack
  2. Re: Manual gearbox oil change
    Jun 2009
    Bromley, Kent
    thanks all. I found somewhere that the quantity is 4.8l and this is what seems to be just right as it is Quattro. I am still digging to find the spec and yes not easy but I will speak with Audi official in a some time but it will be in the next few days. The car has only 85K on the clock but in the last year is not driven regularly, I mean sometimes has not been touch for a month.
  3. Re: Manual gearbox oil change
    Jun 2009
    Bromley, Kent
    Thanks for that, but after I was digging for the oil G055532a2 it comes under petrol engine car models. Could it be a difference as it is diesel and the gearboxes obviously differ? Thank you
  4. Re: Manual gearbox oil change
    Jun 2009
    Bromley, Kent
    HI an thank you
    I looked in the Millers web site and after selecting the vehicle they recommend TRX Synth 75w80 GL5
    Instead of 75W90
    Quote Originally Posted by oilman View Post
    Regards
    Jack
  5. Re: Manual gearbox oil change
    May 2006
    HI an thank you
    Instead of 75W90
    75w-80 for the diff is a bit odd. 75w-80 for the gearbox is perhaps a bit more 'standard' but most people find that a 75w works better, especially from cold. By using something quality, like the Fuchs Sintofluid FE, the better quality of the fluid compared to standard stuff will still give plenty of protection.
    Tim
  6. Re: Manual gearbox oil change
    May 2012
    Everywhere
    308 Post(s)
    Indeed , Fuchs Titan Sintofluid fe sae 75W ( G 052 171 ) will be the daddy as its lower in viscosity at low temps making cold shifts easier .
  7. Re: Manual gearbox oil change
    #17
    May 2006
    Yeah, it's very good stuff. My boss uses it in his Leon and I use it in my Volvo.
    Tim
  1. A6 2.0 tdi manual Gearbox/ Transmission how to oil change
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-07-2019, 08:17 PM
  2. manual gearbox fluid change
    By fla in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-09-2011, 08:50 PM
  3. Manual Gearbox Oil Change
    By Northsea in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-09-2011, 09:51 PM
  4. Gearbox Oil Change 5-spd manual
    By ike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2010, 08:23 PM
  5. Question can you change the oil in a manual gearbox?
    By N47HAN in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-01-2009, 09:46 AM
