Thread: Bad handbrake(on other car)
Results 1 to 10 of 14
  1. Bad handbrake(on other car)
    Jun 2006
    6 Post(s)
    IMG_3644.jpgIMG_3644.jpgJust been given MOT failure ticket on my other Passat as there is a disparity between the amount of pull that the handbrake gives left and right - that is, the left hand side holds slightly better than the right-I know this as I put axle stands under the car. Apart from a shredded piston boot on the right hand calliper everything is okay, no binding etc. The brake pads are decent quality Pagid ones and have plenty of life left in them. I cant see anything wrong with the self adjusters as they took up the 'slack' after about 20 odd pulls of the handbrake lever. Can anyone help? as I cant afford any more surprises. Have just uploaded a pic of the cable compensator under the handbrake. The cable on the right hand side has 'pulled' through more than the left hand one. The thing is, the cable outwardly looks perfect and the inner cable looks fine at the calliper end, so I am still mystified.
  2. Re: Bad handbrake(on other car)
    Mar 2016
    Minervois, France
    54 Post(s)
    Are you sure both inner cables are free in their outer cables?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Bad handbrake(on other car)
    Jun 2006
    6 Post(s)
    Yes, both inner cables are free to move within the outer and I've inspected the outer cable carefully. It's just as if the right hand cable has about 1cm longer inner cable poking out than the left one, if that makes sense?.
  4. Re: Bad handbrake(on other car)
    Mar 2016
    Minervois, France
    54 Post(s)
    I suggest you follow the instructions in the Haynes manual for adjustment, removal and refitting of the brake cables without actually removing them, so that you have the adjustments correctly set.
  5. Re: Bad handbrake(on other car)
    Jun 2006
    6 Post(s)
    Thanks for the reply but the cables cant be adjusted; that is, Any freeplay in the cables is taken up by the self adjusters on the backs of the callipers. Besides Haynes often take the long winded approach to a lot of jobs and with a young family I dont have time to muck around under the car any longer than an hour at a time. Looks like I am going to have to change the calliper as it binds ever so slightly so is probably the piston not retracting back far enough which is causing this left/right handbrake disparity. Just thought someone on here might have had the same problem at MOT time.
  6. Re: Bad handbrake(on other car)
    Mar 2016
    Minervois, France
    54 Post(s)
    Maybe you're right, but I was more concerned about the disparity in the cable lengths and the possibilty that the adjusters have reached their limit.
  7. Re: Bad handbrake(on other car)
    Jun 2006
    6 Post(s)
    The quadrant on the back end of the hand brake lever seems to be pulling left and right hand cable in a uniform amount so I dont think one side has reached its limit as you are suggesting. I think I'll just bite the bullet and change the calliper anyway. Sadly I dont have the luxury of a garage to do this but worse things have happened at sea.
  8. Re: Bad handbrake(on other car)
    Mar 2016
    Minervois, France
    54 Post(s)
    I was thinking also that one adjuster may not have worked properly to shorten its cable, the balancing quadrant has reached a stop on that side, and as a result only one cable is getting the full forvce from the lever.
  9. Re: Bad handbrake(on other car)
    Jun 2006
    6 Post(s)
    I know what you're saying but I've had a look and there is still someway to go before the quadrant would 'bottom out' on its pull to the right hand cable. I've gotta fix this as we are out in the sticks with no public transport. Surely there is a 'tech' reading this.
  10. Re: Bad handbrake(on other car)
    Mar 2016
    Minervois, France
    54 Post(s)
    Sorry I'm not enough of a "tech" for you.
    I must have been wasting my time for years
    As the Big Yin might say. ck'you then.
    0 2 0
  1. Question handbrake
    By acano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2010, 08:32 PM
  2. handbrake
    By artscot79 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2008, 08:25 PM
  3. handbrake
    By c viles in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2008, 09:45 PM
  4. A6 handbrake
    By alogbe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-05-2008, 11:16 AM
  5. Handbrake?
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-02-2008, 09:41 PM
