Thread: Head Unit/Sat Nav/Apple Car Play
  1. Head Unit/Sat Nav/Apple Car Play
    Jan 2018
    Pudsey
    Hey guys,
    New here! Searched and searched for the answer to this but to no avail.
    Car: 59 Plate A4 B8 2.0 Tdi MMI 2g
    I would like to either swap the head unit for an aftermarket one (decent one) that has apple car play. But the problem is then the MMI screen. How do i change the settings on the car?
    OR
    Can I replace the system and upgrade it to a 3G system or a sat nav system?
    Anyone any tips?
    Basically I want to play music through my car via Bluetooth and be able to change the track using my steering controls!
    Thanks in advance!
  2. Re: Head Unit/Sat Nav/Apple Car Play
    Oct 2012
    Estonia
    64 Post(s)
    Google search is key to positive results!
    Not sure, but I have not seen good android unit for mmi 2G, if all you want is bt music stream, check out dension,carlink,vns media etc...
    Some info here regarding bt stream 2g and 3g:Audi-A2DP FAQ - AUDI MMI 2G/3G BLUETOOTH MUSIC STREAMING not sure will it give steering button control also.
    3G retrofit, for many people pointless and expensive...up to you, web full of retrofit threads, as it is 2018 and if you jump to 3G, price difference is more less none, so recommended to 3G+ jump only .
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Head Unit/Sat Nav/Apple Car Play
    Jan 2018
    Pudsey
    Thanks!
    Also seen these too, would this work?
    Rns-e: Vehicle Parts & Accessories | eBay
  4. Re: Head Unit/Sat Nav/Apple Car Play
    Oct 2012
    Estonia
    64 Post(s)
    Noup, 2din old type(rnse etc) units are not for B8!
    Btw, do you have AMI in glovebox?
  5. Re: Head Unit/Sat Nav/Apple Car Play
    Apr 2009
    Have you seen the Android replacement units with Apple Carplay Forbidden
    Sent from my MI 5 using Tapatalk
    Audi A4 Avant 2.0 TDi 2009
  6. Re: Head Unit/Sat Nav/Apple Car Play
    Apr 2009
    Quote Originally Posted by Shaka1976 View Post
    Links are blocked so Google rsnav
  7. Re: Head Unit/Sat Nav/Apple Car Play
    Oct 2012
    Estonia
    64 Post(s)
    In audizine b8 section are long, full of info etc threads also regarding those units!
  1. Apple Car Play
    By MicaBlue in forum Q7 - 4M Forum - 2016 -
    Last Post: 21-10-2017, 08:02 PM
  2. Tip: Getting M4A (iTunes) format music to play on a VW head unit
    By Codestud in forum In Car Entertainment
    Last Post: 08-01-2014, 01:00 AM
  3. How To Replace Concert I Head Unit With Aftermarket Unit
    By Peter Lavoie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2011, 05:08 PM
  4. Replies: 3
    Last Post: 08-09-2008, 05:22 PM
