Thread: heated seat wiring loom
Results 1 to 10 of 17
  1. heated seat wiring loom
    May 2017
    I have a 2007 SEAT Altea 1.9tdi in which I am about to fit the climate control unit from the 09-12 model (5P0907044S) with heated seats. Just wondering is there a wiring kit on the market that would fit this?
  2. Re: heated seat wiring loom
    May 2017
    I have fitted the climate control unit (5P0907044S) on the car and the unit works perfectly. Can someone tell me which plug A,B or C that plug the back of the unit has the wires for the heated seats or do I have do some rewiring for this to work.
  3. Re: heated seat wiring loom
    Mar 2017
    Nottingham
    11 Post(s)
    If the car didn't come with heated seats the wires won't be there, they should be in the 20 pin connector at the back of the heater controls. pin 10. 11, 12, I'm in the process of trying to wire the heated seats I've just put in my golf bit or a nightmare getting a loom. Probably will end up getting one of kufatec website,if you have fitted heated seats when getting the loom make sure you get one for the year of the seats not the year of your car,
  4. Re: heated seat wiring loom
    May 2017
    Thanks Ste81 for this information been waiting ages for this I myself have had so much difficulty trying to get the loom. One thing I wanted to ask you would the universal kits that come with the pads, wiring and switches available on the internet do the same job?
  5. Re: heated seat wiring loom
    Mar 2017
    Nottingham
    11 Post(s)
    Not sure, as my seats have the heat elements in them so not looked into that,
  6. Re: heated seat wiring loom
    May 2017
    No problem just thought it might be an option. You mention that pins 10, 11 & 12 are to do with the heated seats at the back of the climate control do you know which wires go in these pins from the loom?
  7. Re: heated seat wiring loom
    Mar 2017
    Nottingham
    11 Post(s)
    Will be the 3 small wires with the spade ends then there will be 3 wires or two depending if your seats have lumbar support with clips on the end that go into the fuse box then there will be a wire with a round end on it that will go to the car body to be earthed
  8. Re: heated seat wiring loom
    May 2017
    So basically the 3 wires with the spades go into go into the 20 pin connector at the back of the heater controls?
  9. Re: heated seat wiring loom
    Mar 2017
    Nottingham
    11 Post(s)
    Yes
  10. Re: heated seat wiring loom
    May 2017
    Many thanks for your help Ste81.
  1. Heated seat wiring diagram?
    By ajg617 in forum Bora - 1998 - 2005
    Last Post: 23-11-2014, 11:04 PM
  2. Seat Wiring Loom
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2012, 09:53 AM
  3. seat toledo wiring loom
    By krmedboy1 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 22-02-2010, 01:48 PM
  4. HEATED SEAT WIRING help !!
    By highfellzippy in forum Golf MK5 - 2004 - 2009
    Last Post: 25-11-2008, 11:33 PM
  5. How To Heated Seat Wiring
    By davyb69 in forum Audi A3 - Archive Topics
    Last Post: 06-08-2008, 03:19 PM
