Thread: Audi A4 B8 Intermittent starting problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Audi A4 B8 Intermittent starting problem
    Dec 2017
    GB
    Hi all. New to this forum. Im having trouble starting my car first time. It will crank continually without firing up, I will to pull the key out to stop it crank in and straight after I get a low oil level warning then when I go to start it the second time it fires up fine. Anyone else have this problem?.
    Had a new starter put in. Also some cold mornings the battery dies altogether and needs a jump. Not sure if this is related to the first problem.
    Sent from my TA-1033 using Tapatalk
  2. Re: Audi A4 B8 Intermittent starting problem
    Oct 2012
    Estonia
    64 Post(s)
    Without negative, please find someone with vcds and with expirience and let them diagnose your issue(s)...as this guess work is pure waste of time, possibilities are "to many"!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Audi A4 B8 Intermittent starting problem
    Dec 2017
    GB
    Quote Originally Posted by Gunnark100 View Post
    I had a mechanic plug it in to his laptop with no errors showing up. Might have to bring it in to the Audi dealer. Thanks
  4. Re: Audi A4 B8 Intermittent starting problem
    Oct 2012
    Estonia
    64 Post(s)
    Very odd, that no errors at all(at least dead battery should make your scan redish), btw what car(engine)?
  5. Re: Audi A4 B8 Intermittent starting problem
    Dec 2017
    GB
    It is a 2.0tdi 143bhp
    It banboozles me that not error came up as well
  6. Re: Audi A4 B8 Intermittent starting problem
    Oct 2012
    Estonia
    64 Post(s)
    so every time now, it will crank, but will fire up only after you remove key and start again?
    dead battery...could be drain,bad charging,wiring,battery!
  7. Re: Audi A4 B8 Intermittent starting problem
    Dec 2017
    GB
    That's correct. It only happens once every few days. When I first push the key in to start, it will keep cranking over put wont fire up. I then have to to take the key out and try it again, after which starts up 2nd time. Battery is showing over 12v.
  8. Re: Audi A4 B8 Intermittent starting problem
    Oct 2012
    Estonia
    64 Post(s)
    It sounds like first time for some reason fuel will not reach the destination and only second time pump will work! But as always intermittent problems without codes are disaster...but why low oil LEVEL warning ...hmmm
    at least this guy had errorcode
    audi a4 b8 2008 2.0 TDI Help ! intermittent random not starting - ignition switch or starter?
  9. Re: Audi A4 B8 Intermittent starting problem
    Dec 2017
    GB
    Just got back from the Audi dealer. Apparently it is a week battery. They checked it while it was running only reading 8.9v. biggest shock was to find that 2 motor mount and gearbox mount would cost 1200e
  10. Re: Audi A4 B8 Intermittent starting problem
    Oct 2012
    Estonia
    64 Post(s)
    Audi dealer prices are well known! Try to get genuine Lemförder mounts and some good repair shop, and you will save "few" pounds!
    Still strange those battery test results !
  1. Intermittent starting problem...
    By sparksvfr in forum Golf MK3 - 1993 - 1999
    Last Post: 28-12-2010, 05:03 PM
  2. Please Help Intermittent Starting Problem
    By mmdonloaf in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 22-09-2009, 03:27 PM
  3. Intermittent starting problem
    By Manchester_Golf in forum Golf MK4 - 1999 - 2004
    Last Post: 10-07-2009, 06:12 PM
  4. Please Help Intermittent Starting Problem
    By sav8604 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2008, 01:09 PM
  5. intermittent starting problem ? help
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 24-01-2008, 08:44 PM
