Thread: LTFT at idle is around positive 10% - what can be the issue?
Results 1 to 10 of 13
  1. Question LTFT at idle is around positive 10% - what can be the issue?
    Aug 2016
    Debrecen / Hungary
    I have a theoretical question:
    Let's say there's a VW car, naturally aspirated engine, no MAF, no turbo.. just MAP.
    let's say a simple 1.4 or 1.6.. does not really matter. No codes, no driveability issues.
    So the car runs normally - this is only a theoretical question.
    The idle OBD2 LTFT is around 10% but it goes down to around 0% at constant load (cruising..).
    How come LTFT can be 10% at idle but 0% at part throttle? Again, no MAF, only MAP.
    How can I rule out possible issues?
  2. Re: LTFT at idle is around positive 10% - what can be the issue?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Vacuum leak at idle, leaning the mixture and ecu compensating by adding +10% when manifold depression is greatest, lessening as throttle is opened and manifold depression reduces. Just a theory though. Could be coolant temp sender thinking the engine is cold and givng rich mixture at idle, or pre cat o2 sensor exhaust leak drawing in air.
  3. Re: LTFT at idle is around positive 10% - what can be the issue?
    Aug 2016
    Debrecen / Hungary
    Quote Originally Posted by Rob69 View Post
    Thank you for your answer!
    I already changed the throttle body gasket and tried to identify any intake leaks by a smoke machine and a brake-cleaner spary methods (no issues found) and I thought that the MAP-only systems are less "sensitive" to thus I have no idea why it is around +10% at idle. So yes, we share the same theory anyway, an intake leak was my first thought as well but the MAP readings are exactly the same as it was 3 years ago - and in a MAP-only system the MAP should report less vacuum if there is a leak but I sprays the whole throttle body and the whole intake manifold around but not even a small hesitation has been registered during the test and smoke machine test was also negative. Just for safety's sake I already tested the EGR seals and the EGR valve as well but no luck.. yet.. it is not crucial but I just want to know the reason. (LTFT is okay (around 0+-2%) until the ECU registers coolant temp sensor values above 70°C (sensor has been changed last year).) A bit strange.
  4. Re: LTFT at idle is around positive 10% - what can be the issue?
    Nov 2010
    104 Post(s)
    I had similar LTFT issue on a 1.4 polo, ran like that for years and I never got to the bottom of it either.
  5. Re: LTFT at idle is around positive 10% - what can be the issue?
    Dec 2014
    Bedford
    42 Post(s)
    Check oil filler cap seals, if its 16v check the lower neck on the oil filler is 100% tight.
  6. Re: LTFT at idle is around positive 10% - what can be the issue?
    Aug 2016
    Debrecen / Hungary
    Quote Originally Posted by FLAPPERJACK76 View Post
    Thank you for the idea! Already done. No luck. Some mechanics in the local dealership have said to me that this engine (AZD 1.6 16V) cannot let in unmetered air via the oil filler or dipstick holes, the inner architecture is different.
  7. Re: LTFT at idle is around positive 10% - what can be the issue?
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by crok View Post
    Im thinking that this theory is wrong. If you were to leave the oil filler cap half tightened then the ltft would increase on positive as it would be compensated for a weak mixture. I could only prove this if i had an Azd here with me. What is your stft readings. A ltft can be a fairly course measurement. Is the brake servo vacuum pipe leak free.
    For a suspected vacuum leak, note the fuel trims at idle and increase engine speed to 2500 RPM and hold. If the STFT immediately decreases and moves to acceptable levels and the LTFT slowly starts to come back down, you have a vacuum leak.*
  8. Re: LTFT at idle is around positive 10% - what can be the issue?
    Aug 2016
    Debrecen / Hungary
    I tried to spray brake cleaner everywhere, literally everywhere, even around the dipstick and tried to "inject" butane from a butane pen all around the whole engine, every single part, intake manifold, dipstick, oil filler, brake booster and it's hose, the EVAP canister and all it's hoses.. everywhere.. RPM is steady, not even a little bit of change (to make sure it is really butane I let the engine breathe some via the throttle body and that place is the only place where the RPM changed.. STFT is at idle is moving up and down +-5. The signs you described are clear to me (classic signs of a vacuum leak) and yes it seems somewhere I have a leak but I have no more idea where.. : |
  9. Re: LTFT at idle is around positive 10% - what can be the issue?
    Dec 2014
    Bedford
    42 Post(s)
    I hear you. Used to hate these faults year's ago way back when we used vas pc and guided fault finding. The test plan was huge. We used to have vag leak detector spray at £45 a can and it was no bigger than a can of deodorant. Once you have exhausted yourself looking for an air leak consider fuel delivery, injector spray patterns, exhaust restrictions o2 sensors and catalysts. High positive fuel corrections can be traced to MAF and O2 sensor faults, vacuum leaks from intake gaskets/hoses, unmetered air (intake snorkel leak), clogged or dirty fuel injectors, fuel delivery issues, and exhaust restrictions such as a clogged catalytic converter.
  10. Re: LTFT at idle is around positive 10% - what can be the issue?
    Aug 2016
    Debrecen / Hungary
    Thank you, I will go through the list. Again.. Except the MAF, this engine has no MAF (: lot's of stuff are already new, but who knows (:
  1. high LTFT, poor MPG, no fault codes?
    By Rob69 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-04-2013, 08:04 PM
  2. Please Help 2005 Polo 1.4 BKY - LTFT High, Running Rich, MPG down! O2 sensor reading?
    By Rob69 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2013, 09:56 PM
  3. D3 4.2 v8 idle issue
    By instrutec in forum A8 - S8 - V8
    Last Post: 02-06-2010, 12:03 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. Handbrake Issue with positive result
    By forge197 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2009, 08:43 PM
