Thread: ABS and esp light on
Results 1 to 9 of 9
  1. ABS and esp light on
    Jun 2009
    uk
    hi need some help.
    my abs and esp light has been on for a few years on and off intermittently replaced rear right sensor went off then come back on again replaced abs module programmed it was off for a week then back on again.
    after a few months both abs and esp light have been on constantly for like 8 months.
    put it on vag it said rear left sensor needed changing changed that cleared codes was ok for 5 mins then light was back on again but its intermittent again.
    getting these error codes
    2 Faults Found:01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    37-00 - Faulty
    plus steering wheel is very hard to turn on right hand side when car is cold.
  2. Re: ABS and esp light on
    133 Post(s)
    1986 Post(s)
    You need to do the Basic Settings procedure laid out in the Ross Tech Wiki.
  3. Re: ABS and esp light on
    Jan 2009
    Birmingham
    36 Post(s)
    I’m getting the exact same fault codes done the basic setting procedure esp light went off then come back after drive same codes. So I’m thinking of changing the steering sensor at the moment haven’t got the time but that’s my next thing to do.
  4. Re: ABS and esp light on
    133 Post(s)
    1986 Post(s)
    I would check the output from and the centre point reading of the sensor before replacing it, the tracking being set incorrectly can cause the fault code.
  5. Re: ABS and esp light on
    Jun 2009
    uk
    why is the steering wheel heavy to right i have to put a lot of force in to make unlock and turn makes clunk noise when car is warm its ok.
  6. Re: ABS and esp light on
    Jun 2009
    uk
    do you have a link to this m8 my car is audi a4 b6 2001
  7. Re: ABS and esp light on
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by tab99_uk View Post
    A bit of googling brings up this:
    Audi A4 (8E) Brake Electronics (Bosch 5.7) - Ross-Tech Wiki
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  8. Re: ABS and esp light on
    Aberdeen
    63 Post(s)
    Audi A4 (8D) Brake Electronics (Bosch 5.3 ABS/EDS/ASR/ESP) - Ross-Tech Wiki
    Please check this is for your model first!!
  9. Re: ABS and esp light on
    Jan 2009
    Birmingham
    36 Post(s)
    How do I check that crasher any instruction I have Vcds lite
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
