Thread: Remote key - replacement keyring loop
  1. Remote key - replacement keyring loop
    Apr 2017
    Leeds, UK
    Hi all,
    I've got a Golf MKIV key of the type pictured:
    The silver loop onto which you would attach your keyring has snapped off. Short of getting a whole new casing, is there anything I can do to replace or fix it? Can you buy that part separately?
  2. Re: Remote key - replacement keyring loop
    Aug 2008
    Wigan
    9 Post(s)
    I have two old key fobs with that part intact. If you pm your address, I'll post one to you. You should be able to open it up and swap the broken part for an intact one. Maybe try opening up the the one I send to get the hang of it so you don't spoil your good fob?
  3. Re: Remote key - replacement keyring loop
    Aug 2008
    Wigan
    9 Post(s)
    Did you sort out your key fob?
  1. Trying to understand open loop/closed loop and fuel trims on a 2.0T
    By MrBigglesworth in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-05-2015, 09:26 AM
  2. Key fob - keyring
    By kipperphill in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2010, 10:31 PM
  3. VW keyring
    By rover72 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-11-2008, 06:50 PM
  4. Question keyring on key fob
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2008, 08:42 PM
  5. TT roadster keyring
    By D'Squared in forum TT - 8N Forum - 1998 - 2006
    Last Post: 15-07-2007, 09:16 PM
