Thread: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
  1. Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    Jul 2009
    Gateshead, UK
    I'm bit bemused to notice that my front tyres have worn in the middle despite running on the recommended normal pressures of 2.6bar. I'm running Michelin Pilot Sport 4s on the front and PS3s on the rear (at 2.2bar) with 245/40 r18 y xl.
    I'm need to change all four and wondered if it's worth getting PS4s again to replace all, but worried whether they might wear in the middle again, even on normal pressures. I've got about 25,000 miles from the front and about 45,000 from the rear PS3s, mainly motorway and usual commuter runs with the occasional Italian tune-up.
    At the moment, I'm still considering PS4s, as I'm a bit dubious on alternatives. It is a good tyre and always feels surefooted and, being C rated for fuel, has improved mpg. With the PS3s on the rear the tread has sawtoothed, so I get that horrible droning howl. I hope to avoid that with next set.
    Does anyone know why the middles on the fronts have worn with normal pressures?
    Should I stick with PS4s or go for something else?
    Appreciate your thoughts.
    Cheers.
  2. Re: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    May 2012
    Everywhere
    308 Post(s)
    Strange , I've always gone slightly north of 40 psi and have yet to ever experience center wear .
  3. Re: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    Feb 2016
    London
    13 Post(s)
    Have you had a 4 wheel alignment done? 'Sawtoothing' would suggest that something is not right at the rear for a start. Unusual tyre wear can also be a result of worn shock absorbers and/or other worn suspension parts.
    2011 A6 Allroad 3.0TDI
  4. Re: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    May 2015
    Birmingham
    6 Post(s)
    I’m just going to ask the obvious but how are you checking the pressures.
    I have a 2.7 and run barum bravuris 3hm tyres 24540 18 xl 97y and I run 40 front 34 rear. I’ve had a few sets of these so I’ve done some trial and error to get the pressure/ wear just right. Also I think for just motorway Michelin’s are wasted I ran ps3 on mine till I changed to barums and they have good grip and cost half the price but lasted 30% longer.
  5. Re: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    Jul 2008
    Lisburn
    16 Post(s)
    is it a stripped out racer at half the weight?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  6. Re: Front tyres worn in the centre using "normal" pressures - 06 2.7TDi Avant fwd
    Jul 2009
    Gateshead, UK
    I had a closer look with a coin and it does seem that there is also wear towards the inside edge. On the rear the wear is a bit towards the outside. Looks like a four wheel alignment is in order.
  1. Few words about Allroad "normal behavior", please
    By BPApsolut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-06-2014, 11:39 PM
  2. Help with 2.7TDI engine "pulsing"
    By ming in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-10-2012, 09:09 PM
  3. Replies: 3
    Last Post: 20-11-2010, 09:09 PM
  4. What's "normal" battery voltage??
    By Withnail in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2010, 02:47 PM
  5. Audi A4 Avant - Panel Display - "In 1 "or "In 2"
    By infrance in forum Audi A4 - Archive Topics
    Last Post: 05-03-2007, 03:20 PM
