Thread: Bonnet release not working on outside - 2012 Passat B7
Results 1 to 10 of 12
  1. Bonnet release not working on outside - 2012 Passat B7
    Dec 2015
    Scotland
    11 Post(s)
    Hi folks, I desperately need to top up screen wash and coolant!
    i can release the bonnet from inside and it jumps up but the plastic lever on the inner edge of the bonnet lip although moving does not release the bonnet!
    does anyone know how to release it manually I've had a good rummage and can't shift it!
    just to note this is nut like the older pull lever type release you used to get where a plastic rod pops out the grill.
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Bonnet release not working on outside - 2012 Passat B7
    Sep 2009
    Lincoln, England
    6 Post(s)
    Quote Originally Posted by Strath44 View Post
    i can release the bonnet from inside and it jumps up but the plastic lever inside although moving does not release the bonnet!
    Get an assistant to press the bonnet down while you pull lever. Lubricate and work catch before closing again
  3. Re: Bonnet release not working on outside - 2012 Passat B7
    Dec 2015
    Scotland
    11 Post(s)
    Sorry adjusted my wording slightly, the bonnet does pop open so I don't think this will work, it's the next stage that doesn't release from the bonnet catch by hand on the bonnet
  4. Re: Bonnet release not working on outside - 2012 Passat B7
    Jan 2016
    Winchester Hants
    29 Post(s)
    Slid a shimmy in and move that C lever to the left.
    Locked, me pointing at plastic lever
    Unlocked, me pressing the plastic lever.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 68K. Cheat emission software. Nextbase 402G iN-CAR CAM.
    0 2 0
  5. Re: Bonnet release not working on outside - 2012 Passat B7
    Dec 2015
    Scotland
    11 Post(s)
    Thank you, you are a scholar and a gent!! Even more so if you took those photos on my behalf?
  6. Re: Bonnet release not working on outside - 2012 Passat B7
    Jan 2016
    Winchester Hants
    29 Post(s)
    Well yes I did because otherwise it's not easy to appreciate what's going on under there.
    Have you opened it now.
  7. Re: Bonnet release not working on outside - 2012 Passat B7
    Dec 2015
    Scotland
    11 Post(s)
    Thank you that is very kind!
    Yes thanks got it open now, need to find out why the car dropped a load of coolant out the blue but no signs of leaks!
  8. Re: Bonnet release not working on outside - 2012 Passat B7
    Dec 2015
    Scotland
    11 Post(s)
    In case anyone else has to try this I had to rotate the hook to the left of the car (looking at it) I didn't need to hold the plastic lever at the same time it moved with the hook. Mine was sold with crud will need to remove, clean and degrease!
  9. Re: Bonnet release not working on outside - 2012 Passat B7
    Mar 2018
    Used the solution in your posting. Excellent results. Thanks for answering the original post, saved me a trip to the garage.
  10. Re: Bonnet release not working on outside - 2012 Passat B7
    Jan 2020
    Bristol
    Quote Originally Posted by UMEL View Post
    Registered to say thanks very much for this. Mine was so seized up it took considerable force to shift it, at least with your help I was confident I was going in the right direction.
    A bit of cleaning and a lot of WD40/rocking that catch left and right and it's working as it should now.
  1. how can I get the bonnet up, no Bonnet release cable
    By AdamNEUK in forum Golf MK5 - 2004 - 2009
    Last Post: 20-09-2014, 05:28 PM
  2. Replies: 0
    Last Post: 08-01-2012, 09:05 PM
  3. Please Help Passat Bonnet release
    By Flipper_Al in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2009, 11:56 PM
  4. Please Help Bonnet release catch not working
    By Trowel in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2009, 11:44 PM
  5. W Reg Passat - Bonnet Release (at front of bonnet)
    By AndyD in forum Passat - Archive Topics
    Last Post: 01-01-2007, 06:09 PM
