Thread: Fuel pressure issue
  1. Fuel pressure issue
    Nov 2014
    Jersey
    I am suffering a problem with my A3 8P TFSI. Occasionally when accelerating hard under load it will stop at 4k rpm and loose all power but typically return to normal after a few moments.
    I have scanned with my VCDS and get 000135 Fuel Rail/System Pressure p0087-002-Too low-Intermittent. I have logged measured blocks and although I have not managed to replicate the fault with VCDS connected I have noticed that when accelerating the actual rail pressure drops by up to 50% of the specified pressure, often being 50bar less. Is this an indication of the problem? I am not sure whether it is relevant but the fuel pressure regulator value under MBV seems to occasionally sit at a particular value such as -802 or -1114 and when this happens the rail pressure difference is exactly zero. Any thoughts please would be welcome.
  2. Re: Fuel pressure issue
    132 Post(s)
    1980 Post(s)
    What is the engine code and year? If you take the oil cap off, can you smell raw fuel in the oil?
  3. Re: Fuel pressure issue
    Nov 2014
    Jersey
    Hi Crasher, thanks for your reply. It's a 2006 BWA. I will check the oil cap and come back to you.
    Edit: No smell of petrol after a short journey. Will check again after a more enthusiastic drive.
  4. Re: Fuel pressure issue
    Nov 2014
    Jersey
    I attach an excerpt from my VCDS log which shows the rail pressure difference of up to 66 bar when accelerating hard. I'm sure this is the issue, but not sure yet what is causing it. Perhaps cam follower, perhaps pressure sensor is faulty or maybe even the hpfp.fuel press log.jpg
  5. Re: Fuel pressure issue
    Nov 2014
    Jersey
    I may be a step closer to solving this one. I removed the high pressure fuel pump and found the cam follower was worn right through and the end of the fuel pump piston was worn to an angle. Looks like 70,000 miles has taken its toll.
  6. Re: Fuel pressure issue
    Feb 2018
    NZ
    Quote Originally Posted by Keith-i View Post
    Problem solved, it is a common problem.
    Sent from my SM-N920C using Tapatalk
  1. Limp mode, low fuel pressure, air in fuel lines
    By Mowbz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-03-2017, 06:24 PM
  2. S4 - Fuel pressure issue / passenger side exhaust
    By porty in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 26-01-2017, 04:00 PM
  3. Please Help Fuel pressure issue
    By Smudger89 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-01-2017, 12:06 AM
  4. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  5. Fuel pump issue now Fuel Gauge shows wrong amount
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2012, 05:53 PM
