Thread: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
Results 1 to 9 of 9
  1. Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2016
    Co. Antrim
    Hi All,
    I'd really appreciate any advice...I've recently noticed a wiff of blue smoke and lumpy idle for 5 seconds on start up from cold. After that it runs smoothly and no smoke. It has only done 68k, has been regularly serviced and doesn't get abused!! Is this a common fault with the 2.7/3.0 and is there a good sound way of diagnosis ie will a VAGCOM definitely source the problem?
  2. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Most likely injector/s problem. What rail pressure do you have on idle and startup? Does it happen on cold or warm engine? Cold or hot outside temp?
  3. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2016
    Co. Antrim
    Hi, Thanks for the reply...haven't got access to diagnostic gear for the rail pressure but it only happens when the engine is cold. No sign of smoke when warm. Outside temps have also been on the cool side. What would be the best way forward to accurately diagnose this? Thanks
  4. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2016
    Co. Antrim
    Just thought of another potential symptom. Occasionally if the car hasn't had a long run and hasn't warmed up and the engine is stopped for a short while and then restarted...it starts very quickly with a vroom as though there was an excess of fuel in the chambers. It settles back immediately but I wondered if there is a link now that you mentioned injectors. Thanks
  5. Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Yes this could be a cause of an injector fail. This doesn’t mean it is broken. It just doesn’t work in it’s parameters. Occasionaly when you start the car with warm engine, does it happen to hesitate starting? I mean, you put the key inside, turn the key to give power and turn the key to start engine but it hesitates and the lights are flickering and then it starts as normal. Just take the injectors out and put them on a stand. Your injectors are piezo electric bosch so you have to find someone with piezo electric compatible stand so he can make the tests. It is very easy to disassemble the injectors. Remember to change the copper seal and the o ring on the injector itself.
  6. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2008
    40 Post(s)
    Google audi injector problems and settle down for a long read!
  7. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2016
    Co. Antrim
    Hi All,
    Solved!!! Just to close the loop...turns out it was a duff glowplug. Replaced and starting smoothly with no blue smoke!!!
  8. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    May 2008
    40 Post(s)
    Quote Originally Posted by Jonmark View Post
    Hi All,
    Nice a cheap fix, pity they arent all like that
  9. Re: Audi 2.7 TDI Quattro blue smoke and lumpy at start up
    Dec 2015
    Scotland
    11 Post(s)
    what led you to the glow plug, was there a fault code?
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  1. Question Blue smoke on cold start up?
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-01-2012, 11:09 PM
  2. Blue smoke on start up
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2010, 04:48 PM
  3. Blue Smoke on start up
    Last Post: 06-07-2010, 10:02 AM
  4. Blue smoke on start up A6 1.9 tdi
    By Leodisman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-06-2009, 01:03 PM
  5. blue-ish smoke on start up.
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2008, 10:27 AM
