Thread: VW Golf 1.9 TDi Headlamp Failure
  1. Smile VW Golf 1.9 TDi Headlamp Failure
    Lincoln
    Tonight when I turned on my headlamps I noticed that my headlights weren't working. Side lights and main beam worked ok as are tail lights, reverse, interior etc. Checked fuses 1 and 2 (according to handbook 10A) and both of these are ok.
    I haven't been able to do much more checking/testing as its dark but I figure the fault must be on the switch side of things as the lights are on seperate fuses (or is there a relay in there somewhere?) but I was wondering if any of you nice people have seen this problem before...
  2. Re: VW Golf 1.9 TDi Headlamp Failure
    Dec 2007
    I have the same problem with mine, have you managed to find the solution? I do not know what number relay the headlamps work off.
  3. Re: VW Golf 1.9 TDi Headlamp Failure
    portsmouth
    chill lads
    its crimbo eve do you have access to a volts meter or fluke???
    if so check your power supply to the main beam with the switch on as you have done everything else needed ie fuses F11 F12 ,stop looking for relays
    dodgy switch or broken or loose wiring i reckon not much you can do on this fine day.
    have your self a beer merry christmas
  1. Golf Mk4 Headlamp level/dashboard dim switches
    By kenC in forum Golf MK4 - 1999 - 2004
    Last Post: 20-09-2007, 08:00 AM
  2. Passat xenon headlamp leveller failure
    By jetski39590 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2007, 05:33 PM
  3. Golf Mk4- Headlamp Wash
    By bluenose in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2007, 09:27 PM
  4. Engine failure on Golf GTI - Help
    By golfscot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-05-2006, 12:46 PM
  5. Headlamp adjuster stickers on Golf TDi
    By stuart in forum Archive posts
    Last Post: 13-12-2005, 09:47 PM
