Thread: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 49
  1. Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    May 2011
    london
    Good evening all,
    Im after some opinions on my situation. One month ago i purchased a second hand 2013(registered 2014) 2.0 tfsi A4 quattro from a reputable honda dealer with a 3 month rac platinum plus warrenty. The honda dealer said it passed its 100 point check including checking for fluid leaks so it was good to sell to me. It has 52k on the clock. I bought it knowing it needed a service so took it to someone local to me. They have told me it has an oil leak. I have emailed the garage that sold it to me and i am awaiting their reply.
    I would like some opinions on to what my cause of action should be?
    Attached is a photo of the leak taken from underneith
    Thanks in advance
    Matt
    Sent from my HTC 10 using Tapatalk
  2. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Jul 2008
    Essex, United Kingdom
    It can be difficult to spot oil leaks on these cars with the plastic covering underneath. That said, they should know what they are looking for....I suspect the 100 point check wasn't particularly thorough. Either way, in your shoes I'd be going back to the dealer to claim under the warranty!
    -Andrew
    1994 VW Polo 1.4L (Scrapped)
    1998 VW Polo 1.4L - Somewhere Out there...
    2004 Audi A4 1.9TD 130bhp <--Gone but not forgotten!
    2011 Audi A4 3.0 V6 TDi 240bhp - Moved on, but still going
    2017 Audi S3 2.0 TFSI 310bhp
    1 2 0
  3. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Nov 2017
    Scotland
    25 Post(s)
    I wouldnt expect to be seeing oil leaking from a 13plate car unles its been blown up- yeh ok over the top- seals do go,but usualy only after starship milage or been Thrashed, any oil at top of engine-breather etc, weeps from rocker cover ?? a very little oil go's A long way when it gets hot--If you know what I mean !! But If it were me----the car would already be back where I got it from !!!
  4. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Jul 2008
    Quote Originally Posted by Vagnuts View Post
    You can get an oil leak anytime. I agree that you shouldn't expect to see any, but that's still 4 years. I had a leak from my oil cooler which was dumping oil all over the plastic cover under the car. Didn't see it until the EGR valve got changed, and that's in a 2011 car with 60k miles on the clock.
    -Andrew
  5. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Nov 2017
    Scotland
    25 Post(s)
    oh I kmow what your saying, I run a we 03/ a3 asz 130, and the only we bit of oil I started to notice is just starting to weep from the TIP(turbo inlet pipe)-but i still have crankcase breather hooked up so thats where that is coming from-car has done 240.000 last 100.000 on sunflower oil only-we bit of pump stuff when it realy cold but othere than that all is well
  6. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Jul 2008
    My 2008 2.0TDI had also had a small leak from the oil cooler back in 2013, and that was with only 30k miles on the clock.
  7. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Nov 2017
    Gauteng
    Wait you mean to say you put sunflower oil in your engine and it did 100.000?hahahahahah
  8. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    May 2012
    Everywhere
    308 Post(s)
    Guess sunflower oil is a thinner viscosity than veggie oil ?
    I did kill a Peugeot 1.4 derv pump on pure veggie , it used to diesel knock till warmed up a bit .
  9. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Nov 2017
    Scotland
    25 Post(s)
    No I meen "I use sunflower oil to this day and the car runs great-quieter exactly the same performance wee bit beter MPG-infact better since veg oil has a higher cetane number than the pump stuf"-(yeh check that fact !) and at £4.50 for 5ltrs from tesco- am saving a fair bit coin !! for the last oh---25yrs I'v been using it in all my oil burners-no pump, injector, or any other probs, apart from the fact that the first coupl tank fulls ya will need to chenge fuel filter-caus it cleans the the hole system tank and all. My last MOT smoke reading was 0.02 and that was a cold engine !!! down south I believe asda has the best deal on veg--but if you find a chinese supermarket or indian-they use loads so its very cheep- I should mention that the CR's dont like it neet ya have to thin it out but the diesel was first desinged to run peanut oil !!!
  10. Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
    Nov 2017
    Gauteng
    Something you guys are doing wrong to this cars either you are over revving or you making an instant take off everything you are at the traffic light or something
  1. Opinions Wanted.
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-08-2012, 09:33 PM
  2. Opinions on keeping up main dealer servicing
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-01-2012, 03:11 PM
  3. Your opinions wanted on brakes
    By andynpz in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 19-04-2011, 03:59 PM
  4. Please Help Advice/opinions wanted A3 2.0 TDI 170
    By spanglish9978 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-04-2010, 11:12 AM
  5. opinions and insights wanted!
    By ISoskice in forum Passat CC
    Last Post: 17-02-2010, 12:41 PM
