Thread: Help !!!! Passat b6 2.0 TDI 140hp DSG
  1. Angry Help !!!! Passat b6 2.0 TDI 140hp DSG
    Dec 2015
    Macedonia
    I need help if some one have the same issue
    I remove only positiv (+) and the negativ (-) stay on battery... and its fix the problem for only 1 day after the same like on the video....
  2. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Sep 2008
    Bolton Lancs
    6 Post(s)
    I would try removing them both give them a clean and then touch the pos and neg ends together for 30 seconds then reconnect to the battery also clean where the earth cable connects to the body of the car
    the touching of the wires is a bmw trick to put the ecu into sleep mode but it could work on a vw its worth a try nothing to lose
  3. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Dec 2015
    Macedonia
    i was trying everyting and i go to service and they told me ECU is bad...
  4. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Nov 2017
    Scotland
    25 Post(s)
    I would try factory reset of ECU---disconect the batt, leave for twenty mins, reconect bat, key in turn to first position(do not try to start) leave in that pos for 5mins-then withought turning key off first-go for start--leave ticking over for 5mins dont start reving it iether, and leave everything switched off,lights,raidio,heater etc etc. !!!
  5. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Nov 2017
    Scotland
    25 Post(s)
    sorry should have said---if you got VAGCOM/VCDS then just resett it with that !!!
  6. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Dec 2015
    Macedonia
    NEW!!!
    Its not from the ECU we change with the same part number and recode and the car give the same....
    Does some one have idea ?!!!!
  7. Re: Help !!!! Passat b6 2.0 TDI 140hp DSG
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Have you tried a different battery? If that does not work I have heard of a dash cluster electrical fault that could cause such behaviour but the fix is to replace the dash binnacle or have it tested and repaired.
    Hopefully it is not mice!
    Mad Mitch
  1. Correct Alternator for 2.0 tdi 140hp
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-07-2015, 08:23 PM
  2. Correct Alternator for 2.0 tdi 140hp
    By niall campbell in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-07-2015, 08:40 PM
  3. Question P246f problem vw passat cc 2008 2.0 103kw 140hp
    By Addskull in forum Passat CC
    Last Post: 02-09-2014, 02:02 PM
  4. Swapped our 02 115hp 1.9 for 59 140hp 2.0ltr
    By bmwdumptruck in forum Touran - Sharan - Caravelle
    Last Post: 12-06-2013, 10:14 AM
  5. Question Exhaust for 2.0 tdi 140hp
    By Hardcorism in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-11-2010, 04:01 PM
