Thread: TRW or Brake Engineering for Rear Brakes ?
Results 1 to 10 of 12
  1. TRW or Brake Engineering for Rear Brakes ?
    Jul 2007
    glasgow
    35 Post(s)
    With my A6 at 88,000 miles and second set of pads, 46k first and 42k second set now with towing 1,700 kg horsebox a lot of the time ......... I can only wind in my caliper on one side around half way.
    Anyway at 46k it was hard to do, but it did free off and with new discs on, I got a second life out of the calipers and did till just now.
    I have decided at 11 year old, that I am just going to play safe, lazyitis & sort it out, I am going to fit new ones on.
    The problem is that TRW seem to be Lucas made, with them buying out Brake Engineering. The Brake Engineering are more expensive ............. after my Lucas alternator fiasco with my A6, its putting me off the TRW ones, but its weeks before Xmas
    Its the 1KD brakes I have & have the brake caliper & EPB improved/ been modifiednsince 2006 ??
  2. Re: TRW or Brake Engineering for Rear Brakes ?
    Mar 2009
    Montenegro
    13 Post(s)
    I have experince with Bosch and Textar. Bosch was OK except they were making noise after 5000km. Textar are better, no noise at all (after 17000km they are still like new).
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  3. Re: TRW or Brake Engineering for Rear Brakes ?
    Jul 2013
    76 Post(s)
    you could overhaul the caliper ?
    The motor is available in various kits for a lot less than the price of a new caliper.
    The main change is that the motors went from a 6 splined shaft to a 12 splined shaft early ones having the 6 splines.
    Are you sure that the motor/caliper is the issue as the early cars suffer from wiring faults.
    you could swap over the caliper motors from one side to another to make sure that the wiring is good.
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: TRW or Brake Engineering for Rear Brakes ?
    Dec 2015
    Scotland
    11 Post(s)
    What is your mechanical ability? As Dan says the rebuild is pretty straight forward and costs about £30 all in inc piston and seals all in versus a fair bit for the caliper.
    Either way my biggest issue was the brake hose connection to the caliper was pretty rusted and the connection further up to the brake pipe was equally bad!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  5. Re: TRW or Brake Engineering for Rear Brakes ?
    Jul 2007
    glasgow
    35 Post(s)
    My mechanical ability is not too bad, could have and should have done the rebuild myself.
    I went for the TRW in the end
    Time & towing the daughters horsebox meant it had to be fixed fast
  6. Re: TRW or Brake Engineering for Rear Brakes ?
    Dec 2015
    Scotland
    11 Post(s)
    How were the hoses and brake pipes?
    I was planning on going trw if my rebuild din't work!
  7. Re: TRW or Brake Engineering for Rear Brakes ?
    133 Post(s)
    1987 Post(s)
    Technically speaking TRW and Brake Engineering are the same company, I find TRW products are superior but their supply is erratic and can drive me to distraction.....
  8. Re: TRW or Brake Engineering for Rear Brakes ?
    Jul 2007
    glasgow
    35 Post(s)
    Quote Originally Posted by Strath44 View Post
    The pipes were okay actually. The Torx screws holding on the electric motor didnt look too good though
  9. Re: TRW or Brake Engineering for Rear Brakes ?
    Jul 2007
    glasgow
    35 Post(s)
    ................... distraction leads to copious amounts of beer as compensation
    I just didnt know why Eurocarparts had them dearer, which wouldnt have been a problem if they were worth it
  10. Re: TRW or Brake Engineering for Rear Brakes ?
    133 Post(s)
    1987 Post(s)
    When I have the time (a luxury) to order the calipers I need in advance, if TRW list them I will suffer the delay and get them. A current project requires 8L S3 rear calipers/carriers with adapters to make early Golf 3 280-mm front discs (5 stud) fit the back of a Golf 2, yes as odd balls it sounds! I hate reconditioning ally calipers (VAG forbid it) and new carriers from TPS are stupid money but the set from TRW brand new (not exchange, if it has an E at the end of the number it is exchange) was the same one ONE new caliper from TPS and they are THE exact same parts. I ordered them as a set, 2 calipers and a carrrier arrived in three months, the second carrier after another month... Worth it though, unbeatable quality.
  1. Replies: 0
    Last Post: 12-08-2017, 09:44 AM
  2. Replies: 4
    Last Post: 30-05-2016, 12:21 AM
  3. Rear brakes heating after installing new BOSH disks and brake pads
    By avuthless in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-01-2014, 09:59 AM
  4. Question New brakes. Rear brake caliper rubbing???
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2013, 08:03 AM
  5. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
