Thread: Coil light on, cruise control not working and handbrake playing up
  1. Coil light on, cruise control not working and handbrake playing up
    Sep 2008
    I've just bought a 2008 A4 2.0 tdi B8 Avant manual.
    All was well for the first couple of hundred miles but now the coil (glow plug) light will come on and when it does, on braking, the brakes judder. The cruise control is not working and the handbrake sometimes won't disengage. If I turn off the car, when I restart, some times the coil light is out and there is no juddering from the brakes although the cruise control is still not working.
    A couple of times the engine management light has also come on - on fault code scanning it says P2111 which I believe is something to do with the throttle position sensor. If I clear the fault code, the light goes out and can stay out for several hundred miles, but if I wind the car up on acceleration, sometimes the light comes back on.
    Could all of this be related? I'm thinking either throttle position sensor or brake sensor or clutch sensor.
    Should the handbrake automatically disengage if it's on and you drive off without manually disengaging as mine doesn't which is a bit annoying on a hill start.
    Any advice most welcome. Other than these minor irritations I really like the car and hopefully it won't be too expensive to correct...
    Many Thanks
  2. Re: Coil light on, cruise control not working and handbrake playing up
    Sep 2008
    6 Post(s)
    Can't help with fault diagnosis, but hopefully someone will be able to help.
    Regards electromechanical handbrake. Yes, with handbrake on - on a hill, then you should be able to pull away automatically.
    2016 BMW i3 REx (80k)
  3. Re: Coil light on, cruise control not working and handbrake playing up
    Jul 2008
    Essex, United Kingdom
    You need a fault code scan done. It sounds like you've got a fault, causing the car to go into Limp home mode. FYI the cruise control is disabled in limp mode, so its likely you'll get that working again normally once you sort the pre-existing fault.
    I feel your pain with the cost though. These are nice cars, but when they go wrong its the cost of the parts that are usually the biggest kick in the nuts. Paid £50 the other day for a drivers side door mirror glass!!!
    -Andrew
    1994 VW Polo 1.4L (Scrapped)
    1998 VW Polo 1.4L - Somewhere Out there...
    2004 Audi A4 1.9TD 130bhp <--Gone but not forgotten!
    2011 Audi A4 3.0 V6 TDi 240bhp - Moved on, but still going
    2017 Audi S3 2.0 TFSI 310bhp
  4. Re: Coil light on, cruise control not working and handbrake playing up
    Nov 2017
    Scotland
    25 Post(s)
    this is what I'v found re-the code--
    P2111 Throttle Actuator Control System Stuck Open
  5. Re: Coil light on, cruise control not working and handbrake playing up
    Nov 2017
    Scotland
    25 Post(s)
    if you have vagcom- you should be able to do a rest/recalibration !!
  6. Re: Coil light on, cruise control not working and handbrake playing up
    Jul 2007
    glasgow
    35 Post(s)
    you have two separate faults
    1) Brakes . Sticking motor for brakes or motors. Just paid £570 for 2 new rear brakes for my A6 . After driving the car, feel the area round the wheel nuts on the rear wheels, one side may be hotter than the other, this will tell you what side is sticking on. I got lucky and after cleaning sliders, winding the rear caliper in/out a few times, I got another 4 years & 40,000 miles out of tem, but the handbrake was sticky for 9 years. Its silky smooth now
    2) Accelator. The cruise control wont work until this is sorted out
  1. Question Glow plug light flashing and cruise control not working 2.0 tdi 170
    By ThePhoenix in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-10-2022, 09:15 AM
  2. Cruise control playing up
    By kt1966 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-03-2010, 08:59 AM
  3. VW Caravelle cruise control not working flashing glow plug light
    By mundella in forum Touran - Sharan - Caravelle
    Last Post: 17-04-2009, 10:38 AM
  4. airbag light on and cruise control not working
    By printedflunky in forum Touran - Sharan - Caravelle
    Last Post: 05-03-2009, 08:48 PM
  5. A6 Cruise control not working
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 09:42 PM
