Thread: 2008 vw passat 2.0 cr tdi clutch job
  1. 2008 vw passat 2.0 cr tdi clutch job
    Oct 2017
    Ireland
    Hello,
    Recently the flywheel in my passat has started rattling and the clutch bite is very high so its time it got a new kit,
    My question is, Are there any special tools needed to do the job,
    I have the use of a friends lift and ive a good mechanical knowledge,
    Any other advice on torque values etc would also be great
    Thanks in advance
  2. Re: 2008 vw passat 2.0 cr tdi clutch job
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    T10096 subframe alignment pins or Sealey equivalent.
    A decent clutch alignment tool.
    Hoist, support bar or gearbox jack preferable.
    The rest is basic unbolting, renewing and bolting back on (to torque specifications as required).
    Done quite a few of these now for friends and family - reasonably straight forward for someone good with the old spanners.
    Mad Mitch
  3. Re: 2008 vw passat 2.0 cr tdi clutch job
    Oct 2017
    Quote Originally Posted by Dbhead10 View Post
    flywheel - 60Nm+ 90°, use new bolts
    clutch pressure plate - 20Nm, if the plate is LUK - 13Nm
  1. Replies: 6
    Last Post: 30-07-2016, 10:06 PM
  2. Question Sharan 2008 - Clutch problem
    By LA9SHA in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 11:46 AM
  3. Question Whoosh noise when clutch released on 1.9tdi Touran (2008)
    By C Mitchell in forum Touran - Sharan - Caravelle
    Last Post: 24-01-2013, 04:42 PM
  4. 2008 tdi 105 golf clutch help
    By Rudidudi in forum Golf MK5 - 2004 - 2009
    Last Post: 12-09-2012, 12:30 PM
  5. Passat 4wd 140 TDi 2008 & OBD-II elm 323
    By amemo06 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-03-2008, 05:03 PM
