Thread: 95 audi 80 TDI Drivers lock problem
  1. 95 audi 80 TDI Drivers lock problem
    HI
    I have a strange problem with the drivers lock on my 80, which apart from this is great.
    If I mistakenly try the handle before unlocking it, the drivers door cannot be opened at all, not even from the inside, all others are ok.the lock button pops up as normal.I have to then open the rear door and operate the mechanism with a special tool (bent coathanger) and the door then operates as normal with no problems.anyone else had this fault.
    Del
  2. Thumbs up Re: 95 audi 80 TDI Drivers lock problem
    paul20v Guest
    hi
    mine did that and i changed the door lock
    if you dont try the handle i take it every thing works fine
    thats what mine was doing any way
    and you can change the lock without stripping the door panel off to which is even better
  3. Re: 95 audi 80 TDI Drivers lock problem
    OK Thanks
    yes, it all works as expected when its unlocked first, i take it that its relatively easy to change the lock itself?.
  4. Re: 95 audi 80 TDI Drivers lock problem
    paul20v Guest
    hi
    yes its done in the catch you can see on the outside of the door just undo the screws and change it it slips off nice and easy
  5. Thumbs up Re: 95 audi 80 TDI Drivers lock problem
    OK, Its now sorted, ended up taking the lock off and found a small spring
    snapped inside that was allowing one of the sliding bars to move incorrectly, replaced
    with one from a scrap lock.
    Del
  1. A6 Drivers Door Lock Jammed?
    By MetalMan in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-07-2008, 02:49 PM
  2. Drivers Door Lock - Broken
    By Paulpro in forum Polo - Derby - Lupo - Fox
    Last Post: 17-02-2008, 10:55 AM
  3. Sticky drivers door lock
    By Izalman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2007, 07:23 PM
  4. Intermittent Drivers Door Speaker problem!!!!
    By Skoller in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2007, 11:58 AM
  5. Drivers exterior door handle problem
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-04-2007, 09:24 AM
