Thread: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
Results 1 to 8 of 8
  1. Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Dec 2015
    Scotland
    11 Post(s)
    Hi Folks,
    well with the brakes sorted for now the next issue I have - the car kangarooing (wouldn't call it a shudder) the tacho dances (+/- 500) particularly in 2nd between 1500 to 2000 revs. I drives and pulls smoothly in all other situations.
    Since we got the car it has had the issue it seems worse in warm weather but never goes away.
    The car has always thrown up P3007 G40 cam shaft sensor error. I talked to our audi specialist and they said that is a rare sensor to fail and in his opinion unlikely (not seen the car). If it is that its a timing belt off job to replace the sensor. He asked when the belts were done (at 80k ish and not in my ownership but documented).
    The audi specialist thinks it could be a timing issue is this possible?
    Now I did a full scan after the brakes for a laugh and now getting a G28 crankshaft error and a P1588 solenoid mount error as well.
    A quick google suggests that the G28 & G40 errors can be linked?
    Any feedback greatly appreaciated or next moves appreaciated.
    I don't really want the garage to start firing parts at the car if I can do some fault finding first!
    ps full scan below
    Chassis Type: 4F (4L0)
    Scan: 01 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53 56
    61 62 72 77
    VIN: xxx Mileage: 215490km-133899miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    77-Telephone -- Status: Not registered 0001
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Part No SW: 03G 906 016 MH HW: 03G 906 016 MH
    Component: R4 2,0L EDC G000SG 1144
    Revision: --H06--- Serial number:
    Coding: 0000072
    Shop #: WSC 02325 785 00200
    VCID: 75042FDBDCCE66BAE6A85C-8020
    3 Faults Found:
    005512 - Engine Mount Solenoid Valves (N144/N145)
    P1588 - 000 - Open Circuit
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 169436 km
    Time Indication: 0
    Date: 2016.05.17
    Time: 14:30:25
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    012295 - Camshaft Position Sensor (G40)
    P3007 - 000 - No Signal - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 255
    Mileage: 169439 km
    Time Indication: 0
    Date: 2016.05.18
    Time: 17:50:04
    Freeze Frame:
    RPM: 1596 /min
    Speed: 64.0 km/h
    Load: 10.2 %
    Voltage: 13.83 V
    Bin. Bits: 00101000
    Idle Stabilization: 0.0°KW
    (no units): 48.0
    000801 - Engine Speed Sensor (G28)
    P0321 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 214724 km
    Time Indication: 0
    Date: 2017.10.15
    Time: 10:57:40
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 00101000
    RPM: 168 /min
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020855
    VCID: 65247F9B6C6E963A56C80C-8030
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 214724 km
    Time Indication: 0
    Date: 2017.10.15
    Time: 10:57:40
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x0027
    Hex Value: 0x0197
    Hex Value: 0x00FF
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 214724 km
    Time Indication: 0
    Date: 2017.10.15
    Time: 10:57:40
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x0028
    Hex Value: 0x0197
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Revision: 09010701 Serial number: 10601501008322
    Coding: 0000017
    Shop #: WSC 02323 785 00200
    VCID: 63206183625AE80AB8DC12-8036
    Subsystem 1 - Part No: 4F0 910 131 D
    Component: FBSAUDIC6 EZS H46 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    No fault code found.
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 H HW: 4E0 035 729
    Component: Interfacebox H43 5140
    Revision: 00000000 Serial number: 350B%087859599
    Coding: 0000002
    Shop #: WSC 02335 785 00200
    VCID: 28BA36AF5BFC4B52ADAEED-807C
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000000987666
    Subsystem 3 - Serial number: 0104.02.080000000100010769ÿ
    Subsystem 4 - Serial number: 010769ÿ
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 197963 km
    Time Indication: 0
    Date: 2017.03.30
    Time: 19:15:48
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000030327507
    Coding: 0001044
    VCID: 1CD21A7F1FA497F2392661-8048
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0001101
    VCID: 318CDBCB68260A9A7AD048-8064
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H11 0040
    Coding: 00022800
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H46 0390
    Revision: 00046002 Serial number: AUZ5ZBH4082323
    Shop #: WSC 00000 000 00000
    VCID: 1ADE1C671590E9C22B3A77-804E
    Address 0F: Digital Radio Labels: None
    Part No SW: 4E0 910 563 C HW: 4E0 035 563
    Component: DAB-Tuner H41 0830
    Revision: 00000001 Serial number: KE1276V8201339
    Coding: 0000001
    VCID: 24A2229F27D4AF328156D9-8070
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0WRBH2
    Coding: 0013381
    VCID: 29BC33AB40F6725AB2A090-807C
    Subsystem 1 - Serial number: 6332CSME34252742X
    Subsystem 2 - Serial number: 6342CSME34414436Y
    Subsystem 3 - Serial number: 6352QSME5352121B7
    Subsystem 4 - Serial number: 6362QSME53294039D
    Subsystem 5 - Serial number: 63734SME53624E0D5
    Subsystem 6 - Serial number: 63834SME52367921.
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H03000 Serial number: 90025080420371
    Coding: 0102041
    VCID: 27B8359356E2442AA4B4E6-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
    Component: KOMBIINSTR. M73 H23 0240
    Revision: 00000000 Serial number: 72W53AJ28
    Coding: 2308458
    Shop #: WSC 11111 111 11111
    VCID: 23A0218322DAA80AF85CD2-8076
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B0821282D9
    Coding: E5519E53302A0600
    VCID: 2DB4C7BB741E6E7A5EF8A4-8078
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 215371 km
    Time Indication: 0
    Date: 2017.10.23
    Time: 14:23:20
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
    Component: MNS ECE H51 1050
    Revision: 00000000 Serial number: 364B.087761498
    VCID: 308ADECF632C039275DE45-8064
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00000000 Serial number: €‘H
    Coding: 0002586
    Shop #: WSC 02327 785 00200
    VCID: 2CB2CABF4F0467724986B1-8078
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01099170820000
    Coding: 0000251
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
    Component: Amp.-ASK-RD H07 0270
    Revision: S1400000
    Coding: 030000
    Shop #: WSC 02399 823 56573
    VCID: 28BA36AF5BFC8B52ADAEED-807C
    1 Fault Found:
    02095 - Component Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 24
    Reset counter: 110
    Mileage: 30654 km
    Time Indication: 0
    Date: 2009.04.12
    Time: 16:13:54
    Freeze Frame:
    Voltage: 11.90 V
    Temperature: 26.0°C
    Bin. Bits: 00000011
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000520661
    Coding: 0001104
    VCID: 5E5650774938C5E297925B-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00000000 Serial number: gPP
    Coding: 0002586
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000111
    Shop #: WSC 02145 785 00200
    VCID: 20AA2E8F33CCB312E57E35-8074
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 394B.087867245
    Coding: 0000001
    VCID: 2EB6C0B77918156267F2AB-807A
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
    Component: J0644 BEM H12 0760
    Revision: 00000000 Serial number: 00000000027733
    Shop #: WSC 00546 210 60833
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2802203044
    Coding: 344630393135313035442056413032383032323033303434
    Shop #: WSC 00000 384 00290
    2 Faults Found:
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 42497 km
    Time Indication: 0
    Date: 2009.09.22
    Time: 13:19:58
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 42497 km
    Time Indication: 0
    Date: 2009.09.22
    Time: 13:26:24
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0002050
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0002050
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H16 1130
    Revision: 00000000 Serial number: 00000007596413
    Coding: 0010910
    Shop #: WSC 20079 133 80215
    End-------------------------(Elapsed Time: 02:25)--------------------------
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Jul 2013
    76 Post(s)
    Firstly the battery maybe low as there battery related errors on the scan.
    The Can gateway list needs to be checked as it seeing 77 telephone not registered so the Bluetooth module may have blown the fuse or it may be dead.
    The Engine sensor can be checked for irratic readings in the measuring blocks.
    Google audi portal
    The ABS fault maybe either a battery thing or its because of the Engine issues.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Dec 2015
    Scotland
    11 Post(s)
    Thanks Dan (def owe you a beer by the way at some point!)
    i wondered if the Abs fault was from the huge metal particle build up from the brake worn to the shin!
    the battery I will check the age and enable the meter in vcds on the mmi!
    i installed the Bluetooth my self I didn't code it wonder if that is causing an issue going by someone else I think all I did was enable it in the mmi
    i see tonight that there is a bit of oil down the engine side and on the mount will need to see if it has caused any issues
    as per a previous thread that was never concluded can you go into measuring blocks and check the kw/ crackshaft angle on my car to see if the timing is out?
  4. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Jul 2013
    76 Post(s)
    The MMI battery meter is not worth anything.
    Get the battery capacitance checked.
    I have one of these Digital 12V Car Battery Tester Auto Vehicle Battery Analyzer AGM GEL MICRO-200 | eBay
    Whislt a battery will charge the cca of the battery may have dropped so in theory is only holding half a charge or less.
    I believe that the engine mount can be lived with the error and is not to critical.
    Did you check the 77 module in the Can gateway? if not just do that to recode the gateway and that will solve the gateway error.
    Dan
  5. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Jul 2013
    76 Post(s)
    Dan
  6. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Dec 2015
    Scotland
    11 Post(s)
    Thank Dan, good to know about meter and battery will have a look
    will check the 77 module with vcds at the weekend, clear all the codes and see what pops back up in a week or so as this week is getting busy!
    total pita!
    the audi specialist I work next to were having a debate (friendly) with their neighbouring garage as to the best route specialist is wanting to do full new belt job and both G28 & G40 sensors probably water pump I'm sure circa £450 - £600 all in - could do without that pre christmas!
  7. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Aug 2010
    Leeds
    you ever get this sorted im experincing somthing similar at the moment?
  8. Re: Kangarooing / Revs dancing at 1500 to 2000 in low gears multiple sensor error codes! Help!
    Dec 2015
    Scotland
    11 Post(s)
    Hi it was indeed fixed by replacing the sensor behind the cam belt g40 I believe impossible to do without removing the belt I’m afraid!
  1. Split hose intercooler with hesitation at 1500-2000 revs - repair routes!?
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-05-2017, 11:40 AM
  2. Please Help Audi A3 170 TDI Kangarooing at low revs
    By j_caie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-09-2016, 02:53 PM
  3. Question Audi A3 8P rough idle multiple codes (Lamda sensor/camshaft)
    By briuzila in forum VCDS - Help Requests
    Last Post: 10-06-2016, 12:13 PM
  4. Audi A6 2008 hesitation / stuttering / pulsing at 1500 to 2000 revs
    Last Post: 19-05-2016, 02:20 AM
  5. audi a4 3.0 tdi Auto quattro jumping judder between 1500-2000 revs
    By skans786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-04-2013, 11:43 PM
