Thread: Google earth not loading
Results 1 to 10 of 14
  1. Google earth not loading
    Feb 2013
    Gloucester
    57 Post(s)
    Anyone else had this issue? Basically my GE isn’t loading and the option is greyed out on the menu. I’ve tried an MMI reset with no change. Checked I’ve got a data connection with remaining data allowance, I do and it works. Left it for 24 hours and tried again, no change.
    The option is still greyed out and just offers me traffic, or the normal view.
    Any ideas?
    Sent from my iPhone using Tapatalk Pro
  2. Re: Google earth not loading
    Dec 2015
    London
    13 Post(s)
    There’s another thread here on this mate
    I have the same issue too (was saying google maps were restarting). Learnt in that thread that Audi were doing some upgrade.
    1 1 0
  3. Re: Google earth not loading
    Feb 2013
    Gloucester
    57 Post(s)
    Ah sweet thanks. Only really use the car to commute on Sundays and back home Fridays now so hopefully it’s sorted by then.
  4. Re: Google earth not loading
    Mar 2008
    11 Post(s)
    Whole bunch of people on twitter going on about it too although the loaner I'm in (Q5) currently it seemed to be fine today
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  5. Re: Google earth not loading
    May 2016
    swansea
    7 Post(s)
    I'm having the same issue too. GE not.loading and current version of maps is out of date. I got lost ☹️😓
    Sent from my SM-G955F using Tapatalk
  6. Re: Google earth not loading
    Mar 2008
    11 Post(s)
    The Q5 loaner has also now stopped and stuck in the ages again. Like going back to CRT televisions
  7. Re: Google earth not loading
    Dec 2015
    London
    13 Post(s)
    None of my other online functions are working either - like picking up a location sent to the car (via mobile app.)
    Are those working for u guys?
  8. Re: Google earth not loading
    Feb 2013
    Gloucester
    57 Post(s)
    Not used it today but nothing as of yesterday.
  9. Re: Google earth not loading
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by JayNana View Post
    Please refer to the other topic about this issue, it seems, that the problems were solved yesterday/today.
    However, I had a little bit different solution, I had to enter to the my.audi.* menu, check for the "Audi connect" features, and there was a RED ERROR MESSAGE. After the page was reloaded, it became green, but there was a different Audi PIN code. Probably, your car still asks for this new code, however yesterday my PIN code changed back to the former one.
    What I can suggest to you is to check the PIN code in the my.audi.* and see, if it was changed, or is there any error. After I did the above "trick", my system went online without any problem, and all the others system went online about a day later. Probably, you had the same issue as I had, it worth a try to check the Audi PIN code in the my.audi.* system.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  10. Re: Google earth not loading
    Mar 2017
    Northampton
    Still without google maps? Tried resetting the data module off and on, tried taking SIM out and back in etc. All numbers match on the my Audi account but still not able to get Google maps to re set? Anyone else having any luck?
  1. Google maps not loading
    By nicegraham in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-05-2016, 01:41 PM
  2. google earth - just a data sim ?
    By Adrian James in forum A7 - S7
    Last Post: 11-09-2015, 04:52 PM
  3. Snowy google earth!
    By M1tchy in forum A7 - S7
    Last Post: 15-08-2014, 10:42 PM
  4. Google Earth Maps on MMI Nav Plus
    By ianfarnham in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-02-2012, 02:05 PM
  5. Google Earth
    Last Post: 05-11-2007, 07:57 PM
