Thread: Torsion value
  1. Torsion value
    Mar 2017
    Nottingham
    11 Post(s)
    Had new cambelt warter pump fitted today by Vw, before it was done the torsion value was -2.0 now after its -3.4 is this ok car seems fine though????????
  2. Re: Torsion value
    134 Post(s)
    2022 Post(s)
    I bet if the crank was plated up the cam pin would not go in.
  3. Re: Torsion value
    May 2017
    Cardiff
    12 Post(s)
    It's supposed to be near/around 0.
    People have reported increase in fuel consumption and/or loss of performance with increase in torsion value away from 0.
    Suggest you keep an eye on your fuel consumption to compare with previous.
  4. Re: Torsion value
    134 Post(s)
    2022 Post(s)
    VAG call it the "Synchronisation value" and specify it must be -3° > =3° CA (camshaft angle presumably) and in their literature only list
    G40 defective
    Sender incorrect or incorrectly secured
    Gap between sender and camshaft sprocket not ok
    Wiring open circuit or hub with sender wheel on camshaft twisted or loose
    as explanations for figures outside of the tolerance, no mention of valve timing BUT it quite clearly does have a relationship with cam timing accuracy.
  1. Please Help Camshaft torsion value
    By WinDrop in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-01-2016, 02:19 PM
  2. Torsion Value
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-04-2014, 01:11 PM
  3. torsion value of 6???
    By ejs1995 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-02-2014, 07:01 PM
  4. Torsion Value on A4
    By Nigel F in forum VCDS - Help Requests
    Last Post: 28-08-2009, 09:40 PM
  5. Question VW LT 35 front torsion bars.
    By rob20087 in forum The Commercial Range
    Last Post: 30-06-2009, 05:29 PM
