Thread: A4 cab - Electrical gremlins??
  1. A4 cab - Electrical gremlins??
    Liverpool
    11 Post(s)
    No used the A4 since Friday, come out to it this morning and when i opened it up, the driver seat was all the way back (couldnt reach the peddles) and both wing mirrors were pointed down (the housings were fine, hadnt been knocked), but both mirrors were dipped, as though car was going to reverse. Car is secure and on a driveway, no ones been in it, just wondered if anyones ever had anything like this happen with their Audi??
    Strange...
  2. Re: A4 cab - Electrical gremlins??
    scotland
    39 Post(s)
    Water ingress to comfort control module on passenger side floor.
  3. Re: A4 cab - Electrical gremlins??
    Liverpool
    11 Post(s)
    Thanks Calum, will check it when im home this evening. So water ingress could cause things like that to happen??
  4. Re: A4 cab - Electrical gremlins??
    scotland
    39 Post(s)
    Have you seen posts regarding water ingress on A4?
    Water will play havoc with electrics, usually the pollen filter area is where it gets in.
    Water in Passenger Footwell.Audi A4
    Take your pick from these guides: https://www.youtube.com/results?sear...+water+ingress
  5. Re: A4 cab - Electrical gremlins??
    Open the bonnet & clear out all the dead leaves, especially this time of year, water channels get blocked & it finds another place to go
  6. Re: A4 cab - Electrical gremlins??
    Feb 2009
    Do you have memory seats or not?
    For non memory seats, each seat has a control module in its base, the mirrors attach to the window control module in the door as does the control knob. if you have memory seats, there is a second control unit in the base of the drivers door and the memory buttons are wired back to the window control unit in the drivers door. this sends the signal to the seat control modules using the canbus.
    check the door module to see if it is ok, also check the wiring between the A pillar and the door - this is known to suffer from breakages.
    Scan the seat control modules - this might give you some clues.
    W.
  1. Electrical gremlins
    By Rastapopolos in forum Alhambra
    Last Post: 22-06-2014, 11:58 PM
  2. Electrical Gremlins?
    By Plife in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-10-2013, 04:41 PM
  3. electrical gremlins
    By Alaska in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2013, 01:31 PM
  4. A6 2.5 TDI Electrical Gremlins !.
    By jahgti1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-05-2011, 05:30 PM
  5. Electrical gremlins
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-04-2008, 11:06 PM
