Thread: removing ecu cover
Results 1 to 8 of 8
  1. removing ecu cover
    Fareham (hampshire)
    hi,
    i'm trying to find out why water is getting into my drivers side footwell by the brake pedle, and have been trying to get the ecu cover off so i can see if the water is some how getting in that way through a dranage hole under the box but i'm having trouble getting the last bolt out at the back of the box under the cover of the wiper arm, dose anyone know how to get to it or am i looking in the completely wrong place to find a dranage hole. i can't find where the water is ment to come out and was going to take the wheel arch lining out to see if it was under there. if anyone could help i would be very greatfull.
    cheers
  2. Re: removing ecu cover
    Belgrade,Serbia
    It is not under the Ecu box.It is beside it.There is a hole just near the firewall on the both sides.
  3. Re: removing ecu cover
    Oct 2006
    As above, remove the battery to access the bulk head drain tubes.
    My guess is that the tubes are blocked the water builds up and fills this space and leaks into the interior when it gets so far up.
    I found mine had leaves blocking the end which didn't flood the bulk head, but I unblocked them from underneath as they drain to above either side of the gearbox. You'll have to remove the rear engine bell pan/cover to get to them so maybe easier to remove the battery.
    Having said all this the ECU seals could be leaky but it would have to be alot of passing water to then get inside. But the more likely scenario is the blocked drain tubes under the battery and the water fills up submerging the ECU box.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  4. Re: removing ecu cover
    Fareham (hampshire)
    cool, thanks for that i will give that a go. i've just about had enough of getting wet feet.
  5. Re: removing ecu cover
    Oct 2006
    Have you had a look down the side of the battery with a torch to see if you can see water? (Preferably with the scuttle panel (the big plastic panel that spans the bulk head) removed)
  6. Re: removing ecu cover
    Fareham (hampshire)
    i did have a little look this morning and there didn't seem to be any water there.when i wash my car you can see foam coming into the footwell and when it rains it only takes a few mins for it to come in.but i just cant see where it is coming in for it to come out by the brake peddle.would there be any rubber seal around that area that needs replacing.
  7. Re: removing ecu cover
    Jan 2010
    omagh
    Quote Originally Posted by baj25 View Post
    hi,
    cheers
    hi to take dash out to chech matrix heater at your feet ..u only need to take out the two top nuts with th big washer on them .. you will have to out wiper moter as well thanks david
  8. Re: removing ecu cover
    Southern County Softy
    20 Post(s)
    hi,
    cheers
    I've had this, the leak was not blocked drains in my case but the seal under the ECU box not seated correctly.
    Sorted with a new box and seals, with smears of sealant.
    A4 2.5 tdi QS (mapped)
  1. removing seats
    By johnxl1s in forum Golf MK4 - 1999 - 2004
    Last Post: 14-02-2008, 09:51 PM
  2. removing cd changer
    By whitegoods in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-08-2007, 01:14 PM
  3. Removing CTS
    By shabs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2007, 11:08 AM
  4. Removing a MK4 Dash
    By The Muts Nuts in forum Golf MK4 - 1999 - 2004
    Last Post: 19-06-2007, 06:54 PM
  5. removing headlights???
    By jkruse123 in forum Audi A3 - Archive Topics
    Last Post: 20-01-2007, 12:36 AM
