Thread: 1.4 TSI Crank Oil Seal
  1. 1.4 TSI Crank Oil Seal
    Sep 2017
    Luton
    I changed the crank front (timing case) oil seal at the weekend. It's not a difficult job but a couple of observations:
    1) That is the strangest seal I've ever seen. The inner lip is like thin card and folds rather than bending like rubber. Be careful fitting this. Anyone know what it's made of and why it's like that?
    2) The centre bolt torque was 150nm + 180degrees. I replaced the bolt and couldn't get much past 90 on a long breaker bar. The bolt that came off was not done up to anywhere near this torque so I'm not that worried but wondering what other folks experience is?
    3) The manual says there should be a diamond washer behind the crank nose bush and an O ring. None were present on mine and I fail to see what the purpose is so it went back the way it came out but should these bits be there or deleted in later years?
    Ta,
  2. Re: 1.4 TSI Crank Oil Seal
    134 Post(s)
    2019 Post(s)
    I am taking a guess here that it is a 2008 ish CAXC engine? These do not use the diamond washer but the O ring N 909 032 01 is definitely there, or should be! The seal is made from Polytetrafluoroethylene or PTFE commonly known as Teflon. The key point with a PTFE seal is that the surface it runs on MUST be absolutely clean and dry and with no trace of oil or grease on the surface or indeed added to the face of the seal, basically as dry and clean as humanly possible. You are taking a huge risk removing the crank pulley on this engine if the crank is not locked with the T10340 pin and you do not use a dial gauge through number 1 plug hole to ensure you are at TDC. The original bolts were often 19mm 12 sided and the new ones 21mm and these must be torqued up to spec or it can come undone, this is so difficult to do that you need the proper 3415 crank pulley locking tool which engages in the pulley slots and bears against the chassis and then a very long and strong bar with a 3/4" drive and it takes so much force that there is a very real danger of dragging the car off of a two post lift. The specified torque is 150Nm+ 180°. Ohh yes, the point of these seals... low drag, reduced Co2, another example of the blinkered obsessed insane race to reduce Co2 at the expense of all else...
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Please Help BRE 2.0TDi Crank Seal Leak
    By Omnipresentdave in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2015, 11:18 AM
  3. HOW TO:- Front Crank Seal Replacement
    By Last Triumph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2009, 11:48 PM
  4. Front crank seal - anyone done it on a 1.8?
    Last Post: 08-02-2009, 09:31 PM
  5. Crank pulley seal oil leak
    By brauser rexel in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2008, 04:07 AM
