Thread: Golf MKIV alternator?
  1. Golf MKIV alternator?
    Mar 2007
    HI
    just want a little advice...
    ive noticed a few problems starting my car - it seems to struggle to start when left overnight and i thought it maybe the alternator and then a few days later a message came on my display and said alternator workshop.
    I was just wondering if anyone knew how much it would cost for a new alternator for my golf mk4 gti? inc labour? also would it be best to get it done at a vw garage or a smaller independent garage?
    cheers
  2. Re: Golf MKIV alternator?
    Mar 2007
    anyone have any ideas? is this something i could possible replace myself? or is it abit advanced for a novice?
    does anyone know how much it would cost for an alternator if it is that??
  3. Re: Golf MKIV alternator?
    Bristol
    i'm having the same problem. usually starts 2nd or 3rd time... hope its not expensive :-S
  4. Re: Golf MKIV alternator?
    Mar 2007
    well i put a voltmeter to the test on my battery and when the car turnsover and is idling it is at 14.5+ when i turn on everything (lights, heaters etc) it drops between 12.5ish - 13.5 depending what ive got on. i assume its normal to drop a few v's when everything is switched on?
    the problem occurs when i leave the car for a long period (say over night) and when i go to start it up it doesnt turnover until you put your foot on the accelerator or until you try to turn it over 2-3 more times.
    So i assume this maybe a problem with the battery not holding its charge? could this be correct? because if it was my alternator then it could fail to start the car at any point of the day regardless of how long ive left it?
    Anyone shed some light on this? or would it be best to get my battery tested when you get a charge put over it before i go a start replacing stuff?
  5. Re: Golf MKIV alternator?
    Mar 2007
    after a more detailed inspection ive noticed a slight grinding noise when i start the engine up from cold. i couldnt hear this originally because ive always started it myself but i got my missus to whilst i had the bonnet up.
    Could i be right in thinking it maybe the starter motor on its ways out?
    and if so how much does one cost?
  6. Re: Golf MKIV alternator?
    Dec 2006
    Manchester
    I'd get the battery checked first....
    The cold weather is notorious for killing batteries.
    Hope you get sorted soon
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  7. Re: Golf MKIV alternator?
    Mar 2007
    just an update really...
    ive had the battery tested and it is ok. the guy had a quick look and said the engine etc is running v.smooth.
    i'm gona take it back on monday when the other fella is in and his gona take a look.
    anyone got any suggestions?
  1. mk 4 golf alternator overheating
    By scammel in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2014, 11:33 PM
  2. MKIV Golf
    By shahid1973 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-07-2007, 12:01 AM
  3. Golf MKIV Shaking
    By sunilnc in forum Golf MK4 - 1999 - 2004
    Last Post: 20-05-2007, 12:15 PM
  4. AC Problems - MkIV Golf tdI
    By Longmover in forum Golf MK4 - 1999 - 2004
    Last Post: 11-04-2007, 01:31 PM
  5. Golf - alternator workshop
    By davemoreton in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-10-2006, 07:25 PM
