Thread: Removal of rear door glass on a 2008 Polo 9N???
  1. Question Removal of rear door glass on a 2008 Polo 9N???
    Sep 2017
    Wales, UK
    I have removed the door card and popped the circular rubber bung to reveal the track and wire mechanism of the regulator but now I am stuck.
    I did a quick search on this forum as well as Google but drew a blank.
    Help please.
  2. Re: Removal of rear door glass on a 2008 Polo 9N???
    Sep 2017
    Wales, UK
    Sorted. I resorted to brute force after much frustration.
  3. Re: Removal of rear door glass on a 2008 Polo 9N???
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If its the same as the fabia rear window you need to remove the plastic roll pins that hold the glass into the regulator one inside the other) using m5 and m8 bolts screwed into the pins then pulled out with the pins. you should see the roll pins throught where you've removed the big rubber grommet.
  4. Re: Removal of rear door glass on a 2008 Polo 9N???
    Sep 2017
    Wales, UK
    Cheers Rob, sort of figured it out after a bit and used different sized screwdrivers to push the pins out. Wasn't intending to used them again so keeping them intact wasn't an issue.
  5. Re: Removal of rear door glass on a 2008 Polo 9N???
    Nov 2010
    104 Post(s)
    ok happy days !! presume you got new ones with a new regulator kit
  1. estate rear quarter glass removal
    By beanmasteruk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-10-2015, 12:56 PM
  2. Polo 52 plate door glass/rear lights
    By vw754 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2010, 11:26 AM
  3. O/S/R door drop glass removal
    By Neil Haldane in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 08:40 PM
  4. Door panel and glass removal...
    By screech in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2008, 03:08 PM
  5. Removing rear passenger door glass
    By proworldinc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2007, 01:41 PM
