Thread: Problem on one side of engine??
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    Hi I'm having one side (passenger side) of my engine getting hotter than the other side (even just on idle) also seems like it maybe running a little rougher? I'm not sure but it's definitely louder on this side I've also got a whistle when revved (more as I let the throttle off) also I have a bit of a sucking noise when i turn the car off (sounds like it's coming from the throttle control flap) not sure if this connected to my problems or even if it's normal but i didn't notice it in the first 3 years i had the car but the sucking noise has been there for a little bit (i think since I had a garage change the egr valve) please help
  2. Re: Problem on one side of engine??
    134 Post(s)
    2007 Post(s)
    I am guessing this is a V6 TDI?
  3. Re: Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    Yes correct 3.0 tdi bmk engine
  4. Re: Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    Any ideas on what's up with it?
  5. Re: Problem on one side of engine??
    134 Post(s)
    2007 Post(s)
    Do you get a vapour like trail of white smoke from the exhaust at idle with a thick unpleasant odour?
  6. Re: Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    I think there has been a bit of white smoke not too sure if it's vapour like and not too sure about any odour from the backend i will have to check tomorrow , under the bonnet and maybe even inside the car there is an odour but i think it's just the smell of heat, what kind of odour am i looking for? What are your ideas? So I can look for it
  7. Re: Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    The heat from one side is pretty hot it had wrecked my bonnet ram and popped the cap up on my washer bottle and the hvac unit was very hot too
  8. Re: Problem on one side of engine??
    134 Post(s)
    2007 Post(s)
    Sounds like typical faulty V6 CR TDI injector syndrome, makes them run lean and get very hot.
  9. Re: Problem on one side of engine??
    Nov 2016
    england
    33 Post(s)
    Thanks for the reply, ah ok i didn't realise there was a common fault with injectors on these what exactly is the fault is it to do with the cr or injectors theirselves? , but would that create a whistle or the sucking noise? Or do you suspect those to be separate issues? Would this show up on vcds? As I did a scan a few weeks back and it didn't pick up on that although it want to do another one tomorrow, weather permitting i get tomorrow to look at my car (the weather hasn't really been giving me the days I can actually look at my car recently)
  10. Re: Problem on one side of engine??
    134 Post(s)
    2007 Post(s)
    The injectors wear, it is a well known and VAG acknowledged problem dealt with by installing an upgraded set of injectors. The noise is usually a blocked breather system caused by poor oil change intervals, i.e. the ones recommuby Audi......
  1. Battery problem now getting a tapping noise on passenger side from engine.
    By Suejohnhow in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 01-02-2017, 09:08 PM
  2. V5 20v engine noise on chain side of engine
    By craig-v5-20v in forum Toledo
    Last Post: 09-01-2015, 11:33 AM
  3. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  4. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  5. loss of diesel from lh side of engine
    By strof in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2008, 08:04 PM
