Thread: Audi d3 exhaust gas temp sensor fault code advice
Results 1 to 10 of 14
  1. Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Hi guys.
    I have the folowing Error. See Pic.
    My question is What's the part No apparently there are 3 or 4 sensors on the d3 for exhaust. Which one do I need and roughly how much am I looking at in terms of cost of part and cost of labour .
    Sent from my SM-N950F using Tapatalk
  2. Re: Audi d3 exhaust gas temp sensor fault code advice
    134 Post(s)
    2007 Post(s)
    On my iPad so I can't give you the number but I think these are genuine only so you should get what you need from a TPS or Audi dealer by quoting the SDC code G235 after they have entered your VIN into ETKA.
  3. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Called tps today and they can't for sure say which one I need. There are 2 possibilities apparently both of which are before the manifold. So I guess the only real way to find out it to get it checked.
  4. Re: Audi d3 exhaust gas temp sensor fault code advice
    134 Post(s)
    2007 Post(s)
    It is listed on ETKA as a G235, PM me your reg number and when I get back from darkest Wales to civilisation, I will look it up for you.
  5. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Thanks. Ov05obm
  6. Re: Audi d3 exhaust gas temp sensor fault code advice
    134 Post(s)
    2007 Post(s)
    I forgot to update my home version of ETKA with my new password so I can't get FI suggestion on the sensor until Monday t work. Guessing a few of the cars details using the 4E type number and ASE engine code I can see G235 as being EGT sensor 1 for bank one which is the right hand side in the right turbo, mounted in the turbine housing itself and has the part number 057 906 088 which retails at £147.38 from Audi or TPS.
    1 1 0
  7. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Appreciate the help. Let me as soon as you do if it is defo right hand side so I can place an order.
  8. Re: Audi d3 exhaust gas temp sensor fault code advice
    134 Post(s)
    2007 Post(s)
    The SDC code G235 in ETKA does not differentiate between left and right, using the workshop system ELSA shows G235 to be "exhaust gas temperature sender 1" and the other side is described as "exhaust gas temperature sender 1 for bank 2 -G236-" so from that we can assume G235 is bank 1 which is the right hand bank as viewed from the drivers seat locking forwards. This means the part number is 057 906 088, the Audi procedure is as follows
    Removing
    All cable ties which are released or cut open when removing must be fitted in the same position when installing.
    Remove starter catalytic converter
    Unplug electrical connector and unscrew exhaust gas temperature sender 1 -G235
    Installing
    Installation is carried out in the reverse order; note the following:
    Fit all cable ties in the original positions when installing.
    Note correct installation position of exhaust gas temperature sender 1 -G235-:
    The electrical connection must point downwards in vertical direction.
    Install starter catalytic converter .
    1 1 0
  9. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Nice 1!
  10. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Update.
    I popped over to the local dealer and ordered the above part. It will take around a week as it's shipped from Germany.
  1. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  2. Audi A4 B8 2.0Tdi Exhaust Gas Temp sensor
    By aaron.ivory.31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2015, 12:22 AM
  3. EML light on and fault code 005212 - Exhaust Gas Temperature Sensor 3
    By Scottiedogg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2013, 09:56 PM
  4. Exhaust Gas Temp Sensor
    By Dougster67 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2011, 05:07 PM
  5. URGENT HELP - exhaust/NOX/Gas temp sensor
    By lyndon79 in forum New Member Introductions
    Last Post: 14-12-2009, 03:20 PM
