Thread: VAS6154A and ODIS 4.1.3 and Win10 x64
  1. VAS6154A and ODIS 4.1.3 and Win10 x64
    Sydney, Australia
    27 Post(s)
    I have been trying to get a VAS6154A working with ODIS 4.1.3 and 4.1.4 on a Windows 10 x64 machine. Using the VCI manager for VAS6154 I can actually see the VAS6154 but when I start ODIS 4.1.4 and try and find the VAS6154A in ODIS-S "extras/diagnostic interface", the VCI for the VAS6154 cannot be found.
    Under device drivers the VAS6154A shows up as a "USB Serial Port" with FTDI driver. This is actually what the VCI MAnager says the device should look like in Microsoft Device Manager. I have also connected to the VAS6154A via wifi and I still have the same problem with ODIS-S being unable to find the device.
    Has anyone got the VAS6154A working with Win10 x64?
    thanks
    A
  2. Re: VAS6154A and ODIS 4.1.3 and Win10 x64
    133 Post(s)
    1987 Post(s)
    Yes I have a 6154A fully working and with full security access but I use Win7 as we found many problems trying to run anything higher, we had numerous Java errors and the instructions VAG provide do say WIN7. My extremely experienced slightly insane (OK, bonkers) IT chap had to slog away for days at it getting it to run, I ordered the discs from erWin and they would not work, he downloaded it from the erWin site and went from there. He said it was THE most difficult software he had ever done. You are fully registered with erWin and VAG with a dealer number arn't you? Have you called the helpline and spoken to Matt?
  3. Re: VAS6154A and ODIS 4.1.3 and Win10 x64
    Jan 2018
    Britain
    I use this VAS6154 ODIS V4.23 on WIN10 test Ok, I don't know whether it is the same as the one you called VAS 6154A
  1. anyone with odis vas in west yorkshire huddersfield needed
    By Quattros in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 07-04-2016, 10:48 AM
  2. Odis 5054a
    By umaiza31 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-08-2014, 09:59 PM
