Thread: Vw Golf Mk3 Inner drive shaft removal n/s
  1. Vw Golf Mk3 Inner drive shaft removal n/s
    Can someone advise me on how to remove the inner drive shaft on a golf MK3 1996 1.4 5 speed. I have an oil leak from the inner side of this inner shaft. we have removed the main drive shaft and old cars I have worked on had a large bolt in the middle of the inner shaft this one has not got one can you help
    Do I need a puller to do this job as ther is not a bolt on this vehicle
  2. Re: Vw Golf Mk3 Inner drive shaft removal n/s
    Like every other job on vw there are spesial tools for everything.u remove the sealing cap in the senter of the flange,behind this there is a securing ring.Get a long leaver and press the flange towards gearbox,this takes the pressure of the flange because there is a heavy duty spring between it and the diff, hopefully u will be able to remove the securing ring good luck
  3. Re: Vw Golf Mk3 Inner drive shaft removal n/s
    Hi Kenney
    Thanks I will give it a go tommorrow and let you know
    Dave
  1. Drive-Shaft Problem?
    By RobDob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-08-2007, 01:25 AM
  2. Drive Shaft/ Cv Joint
    By TANKSTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2007, 11:45 PM
  3. MK3 golf gti hub/drive shaft nut
    By pants78 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-01-2007, 12:27 AM
  4. drive shaft replace
    By vwray in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 09:29 PM
  5. drive shaft
    By vwray in forum Chat - Completely Off Topic
    Last Post: 14-11-2006, 06:10 PM
