Thread: engine control unit relay
Results 1 to 1 of 1
  1. engine control unit relay
    Ok I checked with VW dealer and the ADZ model does not have a ECU relay, also took apart the injector and cleaned it. still having the occasional drop in power whilst cruising and when on roundabouts and lights etc the car losses power and sometimes cuts out, when I feel this happening I take my foot of the accelerator and try again and the power picks up again.. also in neutral or with clutch in if I touch the accelerator and increase the revs then take my foot away the car almost cuts out (but again only when the car has heated up) anyone any ideas? could this be air leak around throttle/injector body, distributor cap or arm, faulty air temp sensor or faulty injector or even a faulty fuel pump?
  1. Passat heater fan & control unit
    By JONDAVIKING in forum Passat - Archive Topics
    Last Post: 22-12-2007, 02:54 PM
  2. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
  3. courtesy control unit
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 10:54 PM
  4. Hazard/Indictor Relay unit.
    By Fritz1 in forum Passat - Archive Topics
    Last Post: 16-11-2006, 05:06 PM
