Thread: 1.6 Tdi - Fans always on, DPF problem???
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. 1.6 Tdi - Fans always on, DPF problem???
    Sep 2017
    Tyrone
    On my 1.6 tdi the fans always run anytime it is drove (been like this since I got it a couple of months ago)
    No faults codes, no warning lights, and no I dont have the air con isn't on when this happens
    The DPF oil ash reading is at 39g - Is this high?
    Any time the car does a regen, if sitting in traffic or at a traffic light the temp guage will rise? (just after a new water pump and timing belt as I thought it was the pump at fault but it still happens)
    Here is some of the figures VCDS displayed:
    Address 01: Engine (03L 906 023 CQ)
    13:28:34
    IDE00433-ENG103279 Particle filter: oil ash volume-MASS_ASH_PF: 39.0743381 g
    IDE00434-ENG102050 Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 3.10 g
    IDE00435-ENG101197 Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -0.04 g
    IDE00436-ENG102397 Particle filter: kilometers since last regeneration-DIST_RGN : 387.3 km
  2. Re: 1.6 Tdi - Fans always on, DPF problem???
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Has the emissions mod been done? If so, take it into a dealer, they should fix it under warranty.
  3. Re: 1.6 Tdi - Fans always on, DPF problem???
    Sep 2017
    Tyrone
    Quote Originally Posted by Alan G H View Post
    I had contacted VW and they told me the car didn't get a recall done to it.
    On the way home from work today it done another regen, only it started to stutter very badly. I.e in 4th at 50Mph and I had to go down a gear to clear and whilst free wheeling and out off gear I floored it and it stuttered again.
  4. Re: 1.6 Tdi - Fans always on, DPF problem???
    131 Post(s)
    1976 Post(s)
    I would take the DPF off and send it for cleaning.
  5. Re: 1.6 Tdi - Fans always on, DPF problem???
    May 2012
    Everywhere
    308 Post(s)
    Dpf cleaning..
  6. Re: 1.6 Tdi - Fans always on, DPF problem???
    131 Post(s)
    1976 Post(s)
    Not what I had in mind, maybe if nobody had never done that then Diesel wouldn't be getting bad press....
  7. Re: 1.6 Tdi - Fans always on, DPF problem???
    Dec 2014
    Bedford
    42 Post(s)
    39grams is getting high . What kind of driving do you do.
  8. Re: 1.6 Tdi - Fans always on, DPF problem???
    Sep 2017
    Tyrone
    Last week I got the car remapped along with the EGR deleted and DPF deleted and gutted out. Now the car drives great, very smooth and no stalling
    However my fans are running constant when the car is up to temp
    Anybody have any ideas?
    0 1 1
  9. Re: 1.6 Tdi - Fans always on, DPF problem???
    May 2012
    Everywhere
    308 Post(s)
    Who did remapping ?
  10. Re: 1.6 Tdi - Fans always on, DPF problem???
    Nov 2013
    Stoke on Trent
    I was having the same problems, so i took mine to a reputable company in Crewe who did the egr fix, gutted the dpf, rolled back the software then remapped it. Dyno'd at 145bhp & 300Nm of torque. Runs perfect with no more regens or fans running.
    1 2 0
  1. Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    By Peter OJ in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2016, 02:02 PM
  2. 2.0 TDI 170 - AC and Fans problem
    By lgd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-03-2015, 08:32 PM
  3. Problem with cabin fans
    By toby01 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-06-2011, 09:49 PM
  4. Mk5 2007 Golf Gti Fans Problem
    By shizy01 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-10-2009, 09:01 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
