Thread: Vibration at speed
Results 1 to 10 of 14
  1. Vibration at speed
    Mar 2016
    Wokingham UK
    I have recently purchased a B8 Quattro 2Ltr that's 3 and a bit years old. There was a lot of vibration when I first purchased the car and dealer fixed most of it by balancing wheels. There's still an irritating/annoying/unacceptable amount at speed. The dealer has now suggested that the wheel vibration is what he would consider to be a "characteristic of the car". Really! I am told the wheels have been "road force balanced" and are spot on. Therefore, end of story from dealers perspective.
    Wheels are 245/40/R18 93Y Pirelli Cinturato p7's. Virtually/are new tyres.
    Any views or ideas on the way forward - suggestion to go back to the garage with?
  2. Re: Vibration at speed
    Jun 2017
    TR
    Engine fixing plastics might be broken. That vibration might come from engine since the vibration suppression cannot be performed by those plastics .
    Recently I have experienced a vibration problem mostly at steering wheel, it has just been fixed which is due to the old tyres having wear on the base completely. I don't think your problem's cause is tyres.
    LG-D855 cihazımdan Tapatalk kullanılarak gönderildi
  3. Re: Vibration at speed
    Jun 2017
    LB
    If you also experience a slight clunk at slow speeds along with vibration at higher range of speed then it may very well be failing engine mounts.
    Sent from my SM-G928F using Tapatalk
  4. Re: Vibration at speed
    Aberdeen
    63 Post(s)
    Try swapping your wheels front to back. You could have a damaged alloy or tyre.
  5. Re: Vibration at speed
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I doubt the dealer would have one/ no how to use one, but a NVH (noise/vibration/harshness) sensor and hooked up to a scope would pin point the vibration. Its not just wheels that can cause a vibration.
    Alan.
    VW T6 150 DSG Camper ŁŁŁ
  6. Re: Vibration at speed
    Oct 2010
    Huddersfield
    Following with interest.....My 63 plate 2ltr A4 has had a vibration on the motorway for a while now, although seems to come and go, lasting for a few weeks on and off.
    Mine is purely through the footwell and pedals, had in to a garage to be looked at once, of course it was at a point where it had stopped doing it!
  7. Re: Vibration at speed
    Mar 2016
    Wokingham UK
    Quote Originally Posted by Alan02 View Post
    The vibration/rumble comes and goes. Would a NVH help in that case? Can you rig it up and drive at speed? Who has a NVH/where do I find a company that has it in the UK?
  8. Re: Vibration at speed
    Mar 2016
    Wokingham UK
    Before the garage did all the wheel balancing the vibration was constant and I never went above a certain speed. Now I can go at all speeds but the vibration/rumble, which is no where near as bad as before, is still present and doesn't appear constant. I travel on motorways daily (same piece so I know the road and surface) and put the car in cruise control at various speeds to find the speed that encourages it the most and just wait. The vibration/rumble will come and go. I now feel the wheel balancing may have been one issue and now gone it has exposed another. Another piece of information is that the differential was replaced at the same time as the balancing sorted as I had a noise from the rear area - that noise from the differential has now gone.
  9. Re: Vibration at speed
    Nov 2010
    hampshire
    I have this. It was bad a few weeks ago due to warped discs. They have been skimmed but not enough so it now only does it between 70mph and 80mph.
    If its worse when u brake then it could be discs.
  10. Re: Vibration at speed
    Mar 2016
    Wokingham UK
    Quote Originally Posted by usmanrrana82 View Post
    Do you do anything to encourage the clunk or does it just happen?
  1. Question Vibration at speed
    By andyjgw in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2014, 05:20 PM
  2. Vibration at speed
    By iwaters in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2011, 09:18 PM
  3. Vibration at speed
    By Paul Goodyear in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-12-2010, 11:48 AM
  4. Question Low speed DSG Vibration... Normal?
    By Mackey444 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-10-2010, 01:41 PM
  5. Mk4 1.6 vibration at speed
    By Mick100 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-01-2008, 09:43 PM
