Thread: 6 speed gearbox problem?
  1. 6 speed gearbox problem?
    Aug 2017
    aylesbury
    Hi all new to this vw thing & thinking was a bad idea
    Passat 130pd 6 speed
    Getting up to 30/35mph theres a whinning noise, noise dont change whilst coasting or accelerating, ive found if you wobble the gearstick it seems to be actually through the gearstick which makes me believe its gearbox
    Ideally i need something reliable due to work
  2. Re: 6 speed gearbox problem?
    Feb 2004
    Yorkshire
    49 Post(s)
    You may get a better response if this was in the Passat section, if you let me know how old the car is I will move it
    This section is for issues with the forum
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  3. Re: 6 speed gearbox problem?
    Aug 2017
    aylesbury
    Hi the passat is a 2003
  4. Re: 6 speed gearbox problem?
    May 2012
    Everywhere
    308 Post(s)
    Common issue with the 6 speed FRK gearbox .
    The Passat B5.5 1.9 tdi is usually a very reliable machine , what happened is VW copied the earlier reliable 6 speed Getrag ELN gearbox and called it an FRK .
    So get a ELN fitted or I believe the 2.5 V6 TDI DQS also fits as both 240mm .
  1. Question Golf 1.4 tsi dsg 7 speed gearbox problem
    By EYBobb in forum Golf MK5 - 2004 - 2009
    Last Post: 22-05-2013, 10:51 PM
  2. Passat 6 Speed Gearbox Problem
    By jeepjunkie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2010, 11:32 PM
  3. How To VW Caddy Van gearbox. 5 speed or 6 speed
    By free2go in forum The Commercial Range
    Last Post: 18-11-2008, 03:35 PM
  4. Can you replace 4-speed gearbox with 5-speed? Golf ryder 1.4
    By Finjamin in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2008, 11:31 PM
  5. HELP ! 03 Passat tdi sport 6 speed gearbox problem
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-08-2007, 07:32 AM
